glens67
Apr 12 2012, 05:10 PM
OK the rollbar pading is giving me some problems.
I have removed the top screws and under screws. It wont budge.
The side pads have coat hooks.
How do you get them off?
Do the side pads have to come off before the top pad?
Thanks
Glen
JamesM
Apr 12 2012, 05:13 PM
QUOTE(glens67 @ Apr 12 2012, 03:10 PM)
Thanks
Glen
Plastic slides off the coat hooks and there is a screw under them.
Top pad probably still has some screws hiding, they always do.
glens67
Apr 12 2012, 05:16 PM
QUOTE(JamesM @ Apr 12 2012, 05:13 PM)
Thanks
Glen
Push the hook up?
I will look again for the umpteenth time
Need more Beer.
Thanks
914itis
Apr 12 2012, 05:17 PM
Yep u need to take off the size pads and the glue that holds the window.
Valy
As far as I remember, the rear window will not fit in with the side or top pads on. You need to remove all of them anyway.
The hooks have plastic covers. Remove them upwards and you'll see a screw under.
You also need to take out the seat belts
Then the backpack will slide DOWN (remove the bottom screws first). There are some hooks at the top of it that hold it in place.
TheCabinetmaker
Apr 12 2012, 05:20 PM
if I recall correctly, the sides must come off and the backpad. The top pad can stay in place.the coat hook cover pulls off to reveal a screw
glens67
Apr 12 2012, 05:58 PM
QUOTE(vsg914 @ Apr 12 2012, 05:20 PM)
The back pad is off already, thanks.
The top pad need to come off so I can replace the latches.
Thanks
Dave_Darling
Apr 12 2012, 06:17 PM
Don't forget the little screws where the targa latches are. My car didn't have them, but they sure made the next car I worked on (I think it was Jenny's orange car?) quite difficult.
--DD
glens67
Apr 12 2012, 11:18 PM
Got the pads off. Thanks
Window was completely loose, Butal sealant came out in one long piece.
THANKS
Glen
