Slight Problem |
Slight Problem |
Dustin |
Apr 17 2012, 05:10 PM
Member Group: Members Posts: 111 Joined: 19-August 10 From: Woodland Hills, CA Member No.: 12,072 Region Association: None |
Hey,
So, I'm a total noob. About a year and a half ago I took my car apart. I replaced my first gear synchro. And rebuilt my entire engine. Today I started the car for the first time. It started easily and idles. I think I got the timing pretty close. However, when I put the car in first gear and ease off the clutch it wants to roll backwards. What did I screw up? Is my engine turning the wrong way or did I flip something around in my transmission? |
pt_700 |
Apr 17 2012, 05:15 PM
Senior Member Group: Members Posts: 1,092 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
oh man! i feel for 'ya dustin.
is it going backwards in only 1st gear? what about the other 4? what happens in reverse? have to ask the obvious... 1st is all the way towards the driver and down, correct (2nd in a "normal" car)? |
Dustin |
Is my diff flipped??
Dustin |
Apr 17 2012, 05:16 PM
Yeah, I know where first is... I'm going to try it in second.
Apr 17 2012, 05:18 PM
So, I'm a total noob. In that case, you do know that 1st is to the left and towards you, correct? Left and forward is reverse ... (IMG:style_emoticons/default/biggrin.gif) PS: Dang, i got beat to it! |
Dustin |
Apr 17 2012, 05:35 PM
Yes, Backwards in 2nd too.
Jake Raby |
Apr 17 2012, 06:24 PM
You installed the diff on the wrong die of the gearbox.. It is "flipped".
Dustin |
Apr 17 2012, 06:35 PM
So, I have to flip the diff front to back or side to side?
Dustin |
Apr 17 2012, 06:41 PM
Nevermind, I'm starting to remember how this thing goes together...
I did this part over a year ago. |
ejm |
Apr 17 2012, 06:59 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Why did you pull the diff to do a 1st gear sychro? (IMG:style_emoticons/default/confused24.gif)
Dustin |
Apr 17 2012, 07:02 PM
I was curious. I knew nothing about cars when I started this. I bought this car just so I could take it apart. I replaced all the oil seals too. I was going to do other synchros but I got intimidated by the gear cluster and decided to just put it back together.
At some point I'll do the rest. I want to drive it though. (IMG:style_emoticons/default/sad.gif) Obviously this was wise of me. |
pete-stevers |
Apr 17 2012, 07:05 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
ITs to bad you didnt go to Docs "tranny" convention....they even let you wear blond wigs...and rebuild trannies
76-914 |
Apr 18 2012, 10:05 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
It's an easy flip.
pt_700 |
Apr 18 2012, 10:23 AM
how about a collective hazzah for the noob who takes apart a 901 and rebuilds his engine to learn about cars?
did you have any assistance or guidance? why the 914? not sure if i'd have the guts to do the same and i've owned and driven mine for almost 20 years. |
Cap'n Krusty |
Apr 18 2012, 10:30 AM
It's an easy flip. Sure: Drain the tranny, remove the nose cover and the shift console or mechanism, remove the gear cluster, remove the side cover, pull the diff, flip and reinstall the diff and then the cover, measure and replace the intermediate plate gasket/shims, install the cluster and the nose cover (with a new gasket) and shift components, fill with oil, and you're done. Not exactly easy, is it? The Cap'n |
dlee1967 |
Apr 18 2012, 10:33 AM
V8Lurker Group: Members Posts: 540 Joined: 20-February 03 From: Splendora, TX Member No.: 327 Region Association: None |
Dustin, although you have a slight hickup in your project, congratulations on diving in to it with abandon. The diff flip is a minor issue and you will get that corrected quickly.
My first car was a Bugeye and I rebuilt it at age 14 with a very sketchy set of tools in my parents carport. Thank goodness there was an MG Midget workshop manual at the public libruary. If we had the internet in 1980 I would have been much more efficient at the project. Welcome to the wonderful of the 914. There was another member in the last week that put his calipers on the front of the car with the bleeders down and wondered why he couldn't get any pedal pressure.............. (IMG:style_emoticons/default/wacko.gif) David Lee |
Dustin |
Apr 18 2012, 11:37 AM
did you have any assistance or guidance? why the 914? I used a local machine shop to check out my engine components and rebuild my heads. That guy answered a bunch of questions that came up along the way. Other then that just the internet. 914, love it first sight. I saw my first one when I was about 8, around 1982. I bought this one in 2005. So I have had some time to do my research. |
Lo-Fi Version | Time is now: 15th May 2024 - 02:16 AM |
