Procedure to remove rocker panel covers |
roundboy914 |
Oct 5 2004, 03:49 PM
Member Group: Members Posts: 210 Joined: 16-October 03 From: Chicago, IL Member No.: 1,251 |
So all this talk about the jack stand points, and now i am worried about the amount of dirt and or rust hiding behind my dented side rocker covers, which are also peeling like a mofo.
I removed the phillips head screws around the door openning, are ther more screws that attach underneath? The cover seems loose, but before i start a yankin', i want to insure that i am not missing anything. |
Carl |
Oct 5 2004, 04:11 PM
Ummm ... what? Group: Members Posts: 781 Joined: 17-January 03 From: San Jose, CA Member No.: 163 Region Association: Northern California |
There are ~four or five hex-head sheet metal screws on the bottom edge. One just to the rear of the front wheel, one just ahead of the rear wheel and the others along the bottom edge in between.
C |
STL914 |
Oct 5 2004, 04:12 PM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
Besides the screws you have already removed, there is one in the front wheel well and one in the rear well, at the ends of the rocker panels. Plus, if you look under the panel you will see 4 or 5 rivets or screws. If rivets, just drill out the heads.
The factory used rivets to secure the panels, but many owners have replaced the rivets with screws to make it easier to remove and replace the panels for maintenance reasons. Hope this helps. |
smg914 |
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
There should be 3 cheese head type screws on the bottom of each rocker panel. Also inside the each front fender well and the each rear fender well should be a very small self taping bolt that secures the rocker panel to the lower finders.
scotty914 |
Oct 5 2004, 05:09 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
(IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) then (IMG:style_emoticons/default/givemebeer.gif) then (IMG:style_emoticons/default/welder.gif) more (IMG:style_emoticons/default/beer3.gif) then more (IMG:style_emoticons/default/welder.gif) and finally (IMG:style_emoticons/default/beer.gif)
or just read above posts that dont include (IMG:style_emoticons/default/beer3.gif) scott thacher |
TheCabinetmaker |
Oct 5 2004, 08:03 PM
QUOTE(smg914 @ Oct 5 2004, 05:12 PM) There should be 3 cheese head type screws on the bottom of each rocker panel. Also inside the each front fender well and the each rear fender well should be a very small self taping bolt that secures the rocker panel to the lower finders. He nailed it! replace the cheese heads with hex head bolts. You may find a nut and bolt in the fender wells if they have been off before. If the top side has phillips screws instead of rivets, then they have been removed before. |
Lo-Fi Version | Time is now: 25th May 2024 - 06:02 AM |
