Need fuse panel picture showing conected wires |
Geezer914 |
Apr 19 2012, 10:18 AM
Geezer914 Group: Members Posts: 1,410 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Does anyone have, or would some one be kind enough to take, a picture of the fuse panel showing how the wires are conected on a 75 914? I replaced the original fuse panel with one from Engman and may have mixed up a wire from front to back. I have a current draw draining the battery. I pulled each fuses and the test light stayed lit for everyone. I even pulled the 2 fuses on the relay board and the voltage regulator, no luck. Any other tips are more than welcome, Thanks
Gudhjem |
Apr 19 2012, 10:34 AM
Member Group: Members Posts: 133 Joined: 29-March 07 From: Castro Valley, CA Member No.: 7,629 Region Association: Northern California |
Does anyone have, or would some one be kind enough to take, a picture of the fuse panel showing how the wires are conected on a 75 914? I replaced the original fuse panel with one from Engman and may have mixed up a wire from front to back. I have a current draw draining the battery. I pulled each fuses and the test light stayed lit for everyone. I even pulled the 2 fuses on the relay board and the voltage regulator, no luck. Any other tips are more than welcome, Thanks Not sure this will help, and it's for a '73, but here you go. It describes where each wire goes. --Steve Attached File(s) 914_Fuse_Box.pdf ( 43.05k ) Number of downloads: 506 |
Geezer914 |
Apr 19 2012, 01:03 PM
Thanks for the chart, but I think 74 and later are different.
falconfp2001 |
Apr 19 2012, 01:19 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
You can compare that chart with these diagrams. I think they are pretty much the same.
http://www.pelicanparts.com/914/914_electrical_diagrams.htm |
Lo-Fi Version | Time is now: 15th May 2024 - 10:56 AM |
