QUOTE(Geezer914 @ Apr 19 2012, 08:18 AM)
Does anyone have, or would some one be kind enough to take, a picture of the fuse panel showing how the wires are conected on a 75 914? I replaced the original fuse panel with one from Engman and may have mixed up a wire from front to back. I have a current draw draining the battery. I pulled each fuses and the test light stayed lit for everyone. I even pulled the 2 fuses on the relay board and the voltage regulator, no luck. Any other tips are more than welcome, Thanks
Not sure this will help, and it's for a '73, but here you go. It describes where each wire goes.
--Steve
