Dodged a Bullet, Oil Leak Found! |
ScottD914 |
Apr 20 2012, 06:49 AM
Member Group: Members Posts: 69 Joined: 27-December 07 From: New London, CT Member No.: 8,506 |
After taking extra care with my rebuild, a pesky oil leak was frustrating. Thinking it was one of the 13 plugs I installed:
I was about to yank the engine and pull it apart. Just for grins, I pulled the rubber plug over my oil sender, started up the engine and There It Was! 10 minutes to swap it out and Done! Somebody, somewhere suggested this as a possibility on another post and saved me hours of work! Thanks!! ScottD |
ConeDodger |
Apr 20 2012, 07:50 AM
Apex killer! Group: Members Posts: 23,586 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Say what you want about George and most will, (IMG:style_emoticons/default/biggrin.gif) his 7 million tech tips are right on the money and this is one of them. A leak on the passenger front is often the oil sender. If not, then the oil cooler.
gothspeed |
Apr 20 2012, 08:03 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I have had the sender leak on a few previous cars ......... good find!!
LotusJoe |
Apr 20 2012, 10:53 AM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
Was it the sender itself that was leaking? |
ScottD914 |
Apr 20 2012, 11:21 AM
Was it the sender itself that was leaking? Yep, right between the terminal and the plastic... (IMG:style_emoticons/default/barf.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 10:10 PM |
