Found my oil leak, What the hell is this ?? |
drdave427 |
Apr 20 2012, 05:33 PM
Newbie Group: Members Posts: 31 Joined: 26-March 12 From: East TN Member No.: 14,306 Region Association: South East States |
I pulled off the drivers side valve cover expecting to find a bad gasket. In an earlier post - "oil where it shouldn't be" - I posted some pics of an above the engine seal line oil leak that occurred after some spirited driving an a HUGE sweeping right turn. I got suggestions that I probably had blown a valve cover gasket - well that was not the problem but it did set up a new question. What is the little tube that goes thru the head into the valve cover ?? I had not seen this tube topside as it is really tight against the intake manifold - and I had the carbs off when I first bought the car. Anyway this tube had nothing connected to it so I am sure its where the oil came from - it is right in the middle of where the oil showed on the tin. Is there 2 crankcase vents on the drivers side ??
My vent tube on that side is connected a little above this newly found opening. Attached thumbnail(s) |
drdave427 |
Apr 20 2012, 05:39 PM
I pulled off the drivers side valve cover expecting to find a bad gasket. In an earlier post - "oil where it shouldn't be" - I posted some pics of an above the engine seal line oil leak that occurred after some spirited driving an a HUGE sweeping right turn. I got suggestions that I probably had blown a valve cover gasket - well that was not the problem but it did set up a new question. What is the little tube that goes thru the head into the valve cover ?? I had not seen this tube topside as it is really tight against the intake manifold - and I had the carbs off when I first bought the car. Anyway this tube had nothing connected to it so I am sure its where the oil came from - it is right in the middle of where the oil showed on the tin. Is there 2 crankcase vents on the drivers side ?? My vent tube on that side is connected a little above this newly found opening. the new open tube is just below the metal line /rubber coupler I have that is going to what I thought was the crankcase vent. The tube isn't visible in the shot -- it is right against the intake manifold. This picture I took right after the oil leak happened. Attached thumbnail(s) |
Apr 20 2012, 05:43 PM
That is the vent tube that we've been talking about.
It is part of the positive crankcase ventilation system. In a stock car, that would get joined together at the "flashback valve" (a screen-style spark arrestor) and connected to the air cleaner. --DD |
drdave427 |
Apr 20 2012, 05:52 PM
That is the vent tube that we've been talking about. It is part of the positive crankcase ventilation system. In a stock car, that would get joined together at the "flashback valve" (a screen-style spark arrestor) and connected to the air cleaner. --DD Then what do I have the hose connected to above it ?? Thanks |
Cap'n Krusty |
Apr 20 2012, 06:17 PM
Sure looks like your vent line is connected to the port in the shroud for the evap hose.
The Cap'n |
drdave427 |
Apr 20 2012, 06:20 PM
brant |
Apr 20 2012, 08:29 PM
yes you can do that
or you can cap the tin work with a plug to stop the small air leak its not too important either way but you need to put a hose on the head vent the head vent is blowing oil out with positive crank case pressure |
drdave427 |
Apr 20 2012, 09:07 PM
yes you can do that or you can cap the tin work with a plug to stop the small air leak its not too important either way but you need to put a hose on the head vent the head vent is blowing oil out with positive crank case pressure Fixed !! Thanks everyone -- I can't believe I was pumping air into the engine. That's not good unless you are turboed-- it was connected that way when I got the car. Actually both sides were connected together and the oil fill breather tube was just laying free. I T'd the 2lines and ran them to the air cleaner and installed a little filter at the oil fill and thought I was doing good ! It is all sorted out now and the valves are adjusted -- they were all a little tight ... |
euro911 |
Apr 21 2012, 03:15 AM
Glad to hear you found and fixed the problem (IMG:style_emoticons/default/thumb3d.gif)
Now you just have to get the oil smell out of the engine compartment if you plan to use the heater (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 06:47 PM |
