Rear Flares, Fiber Glass or composite |
Randal |
Apr 24 2012, 05:22 PM
Looking for rear flares and I believe the size is 11" to fit an 11" slick. I know Patrick Motorsports has them, anyone else? (IMG:style_emoticons/default/dry.gif) |
Apr 24 2012, 05:37 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Looking for rear flares and I believe the size is 11" to fit an 11" slick. I know Patrick Motorsports has them, anyone else? (IMG:style_emoticons/default/dry.gif) I have to look tonight, i have a set of 11" flares and they were either from Getty or AIR ... (IMG:style_emoticons/default/idea.gif) |
Aaron Cox |
Apr 24 2012, 05:52 PM
AIR makes 11" rear GT flares
http://www.americaninternationalracing.com...246&page=59 |
Woody |
Apr 24 2012, 05:54 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
I'm using the 7 and 9 inch flares from these guys along with the bumpers. Fit is decent with the fenders, so so with the bumpers.
http://www.rennspd.com/P_Detail.asp?PID=382&Task=STD (IMG:http://www.914world.com/bbs2/uploads_offsite/i288.photobucket.com-12530-1335311650.1.jpg) |
Randal |
Apr 24 2012, 06:30 PM
Looking for rear flares and I believe the size is 11" to fit an 11" slick. I know Patrick Motorsports has them, anyone else? (IMG:style_emoticons/default/dry.gif) I have to look tonight, i have a set of 11" flares and they were either from Getty or AIR ... (IMG:style_emoticons/default/idea.gif) They will probably be AIR as Getty doesn't make that size. Are you still planning on using them Andy? Actually if your going to do two turbos then you might want bigger ones to cover the huge tires you'll need. (IMG:style_emoticons/default/w00t.gif) |
Cracker |
Apr 24 2012, 08:29 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Here are mine from Rennspeed. It took allot of work but that is dependent on how anal you are... (IMG:style_emoticons/default/unsure.gif)
Correction - My flares are 9" Front...I had listed 7". 9" & 11" (17") Lindsay Racing Fuchs |
Randal |
Apr 24 2012, 10:37 PM
Here are mine from Rennspeed. It took allot of work but that is dependent on how anal you are... (IMG:style_emoticons/default/unsure.gif) 7" & 11" (17") Lindsay Racing Fuchs Very nice work. Did Rennspeed also sell the rocker panel? |
Apr 24 2012, 11:20 PM
Are you still planning on using them Andy? Actually if your going to do two turbos then you might want bigger ones to cover the huge tires you'll need. (IMG:style_emoticons/default/w00t.gif) Yes. (IMG:style_emoticons/default/biggrin.gif) Already got the wheels and tires for them. I just have to get motivated to do the bodywork. Since my cars is all molded in, that will be a major undertaking ... (IMG:style_emoticons/default/unsure.gif) |
bulitt |
Apr 25 2012, 04:15 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Here are mine from Rennspeed. It took allot of work but that is dependent on how anal you are... (IMG:style_emoticons/default/unsure.gif) 7" & 11" (17") Lindsay Racing Fuchs Wow Tony your car looks awesome! How about some more pics! What spring rate did you settle on for the rear, front torsion bar size? and who makes the rear wing? Thanks! |
Cracker |
Apr 25 2012, 07:05 AM
The rockers, trunk w/ spoiler, and flares are all from Respond. I supposedly had all of these glassed as "thicker" than normal - you'd never know it though. If someone is intending to "glass in" the flares these would NOT be the way to go - way to thin. I have seen glass flares that are very tough and rigid - these are NOT them. Perfect for my intended use and they look really good but I can't underscore enough how much work ($$$) went into what you see right there. I could have glassed them for the same price in the end! the entire sides of the car were repainted at the same time due to all the "fitment" scratches and such.
I'm going to start a new thread in "garage" to not hijack this anymore. |
Randal |
Apr 25 2012, 09:55 AM
Here are mine from Rennspeed. It took allot of work but that is dependent on how anal you are... (IMG:style_emoticons/default/unsure.gif) 7" & 11" (17") Lindsay Racing Fuchs Well all the work was worth it as your car looks great. Question: Any pictures of your splitter build and the materials you used? Really nice job and so clean. Have you ever thought of hill climbing that beauty? Some of the Southern events I've seen on line have shown some challenging hills. |
J P Stein |
Apr 25 2012, 10:26 AM
Brit just picked up some monster rear flares that cover the 12s on 12s. I've only seen pics but they look good. You need some of those. (IMG:style_emoticons/default/biggrin.gif)
Cracker |
Apr 25 2012, 10:31 AM
There are no hill climbs in my future. It might take a little while but when I have the front end off I'll try to remember to shoot some pics for you. The splitter is mounted independant of the air dam assembly (other than the two struts which quickly can be removed). As strong as the CF airdam is I wouldn't mount the splitter to it as a main support system.
The spliter is a real CF and Kevlar around foam core unit. It is 1/2" thick with a beveled front and strong as hell. It was made in conjunction with the airdam by Prototype Composites in Milwaukee, WI. (Sp?). |
Randal |
Apr 25 2012, 11:14 AM
Brit just picked up some monster rear flares that cover the 12s on 12s. I've only seen pics but they look good. You need some of those. (IMG:style_emoticons/default/biggrin.gif) Do you know which ones he used? (IMG:style_emoticons/default/idea.gif) |
Randal |
Apr 25 2012, 11:16 AM
There are no hill climbs in my future. It might take a little while but when I have the front end off I'll try to remember to shoot some pics for you. The splitter is mounted independant of the air dam assembly (other than the two struts which quickly can be removed). As strong as the CF airdam is I wouldn't mount the splitter to it as a main support system. The spliter is a real CF and Kevlar around foam core unit. It is 1/2" thick with a beveled front and strong as hell. It was made in conjunction with the airdam by Prototype Composites in Milwaukee, WI. (Sp?). Pictures will be appreciated! |
Randal |
Apr 25 2012, 11:20 AM
There are no hill climbs in my future. It might take a little while but when I have the front end off I'll try to remember to shoot some pics for you. The splitter is mounted independant of the air dam assembly (other than the two struts which quickly can be removed). As strong as the CF airdam is I wouldn't mount the splitter to it as a main support system. The spliter is a real CF and Kevlar around foam core unit. It is 1/2" thick with a beveled front and strong as hell. It was made in conjunction with the airdam by Prototype Composites in Milwaukee, WI. (Sp?). Was the splitter a one off build by Prototype Composites or something they sell? |
sixnotfour |
Apr 25 2012, 12:38 PM
914 Wizard Group: Members Posts: 10,412 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE Do you know which ones he used? GT racing I think. Confirmed via facebook. he has a build thread here also. garage http://www.914world.com/bbs2/index.php?sho...579&st=400# Attached image(s) |
Randal |
Apr 25 2012, 10:32 PM
QUOTE Do you know which ones he used? GT racing I think. Confirmed via facebook. he has a build thread here also. garage http://www.914world.com/bbs2/index.php?sho...579&st=400# Those look like they fit well. Understand they will fit 12" wheels, but not sure how they would look with 11"ers? |
stewteral |
May 15 2012, 09:05 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Looking for rear flares and I believe the size is 11" to fit an 11" slick. I know Patrick Motorsports has them, anyone else? (IMG:style_emoticons/default/dry.gif) Hey Randal, I've been running Rennspeed flares all around, for over 10 years and can recommend them. Their pricing CANNOT be BEAT!! Check out: www.rennspd.com Best, Terry |
Randal |
May 15 2012, 09:08 PM
Looking for rear flares and I believe the size is 11" to fit an 11" slick. I know Patrick Motorsports has them, anyone else? (IMG:style_emoticons/default/dry.gif) Hey Randal, I've been running Rennspeed flares all around, for over 10 years and can recommend them. Their pricing CANNOT be BEAT!! Check out: www.rennspd.com Best, Terry Tks for the information- will check it out. I was at Infineon on Saturday and think I saw your car. Very very nice. No one was around, so missed you. You were parked next to my buddy Mike A. in his 914-6 that needs a paint job! |
Lo-Fi Version | Time is now: 27th April 2024 - 06:35 PM |
