Seats for 914, Sportseats to fit the original padding |
boxstr |
Apr 12 2005, 09:39 AM
Steve, Let me know who the supplier was an dI will try to aquire the material you need and send it to you.
Go to my website http://www.camp914.com I have posted under the GTS seat banner a few of the color samples inculuded is the B/W houndstooth. Craig C. Laughlin |
GTS |
May 4 2005, 11:19 PM
Member Group: Members Posts: 64 Joined: 7-October 04 From: South Austin,TX Member No.: 2,903 Region Association: None |
Just to add the next model ...here is the LeMans in leatherette/corduroy
Stefan GTS-classics.com Attached thumbnail(s) |
redshift |
May 23 2005, 06:01 AM
Oh great, houndstooth makes me horny.
M |
GaroldShaffer |
Jun 1 2005, 07:52 AM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I got my seat from Craig at Camp914. It is great and your stock belts work just fine. I ran my first AX with the seat installed over the weekend and no problem with my (IMG:http://www.914world.com/bbs2/html/emoticons/bootyshake.gif) moving in the seat.
NecronomiconJules |
Jan 4 2007, 12:36 PM
Newbie Group: Members Posts: 7 Joined: 3-January 07 From: CA Member No.: 7,422 |
When mounted, is there a seat height difference compared to regular 914 seats? At 6'.4'' anything higher than stock is out of the question for me.
Jules |
boxstr |
Jan 7 2007, 12:28 PM
Jules, The stock 914 runners mount to the bottom of the LeMans seat. They then slide onto the stock adjuster assembly. There is little to no height change from stock.
Craig C. Laughlin |
jim_hoyland |
Jan 25 2007, 08:56 PM
Get that VIN ? Group: Members Posts: 9,263 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Craig,
Have any Lemans seats been done in Tan/Camel ? jim |
boxstr |
Jan 26 2007, 11:53 PM
No but they can be done in camel or tan.
CCL |
daveyboybadion |
Feb 25 2007, 01:50 AM
Member Group: Members Posts: 108 Joined: 19-January 06 From: Seattle, WA Member No.: 5,437 Region Association: Pacific Northwest |
Hi Stefan, it looks like you finally made the move to Texas. I talked to Craig at Camp 914 and he suggested I get in touch with you directly. I bought a Rallye ST that you delivered to Carl's Place in Las Vegas. I'm looking for brackets that will let me bolt the stock seat slider to the GTS chair. Anything available yet?...daveyboy p.s. to any of you out there considering these seats, they are great looking and well made. |
GTS |
Feb 25 2007, 08:22 AM
[Hi Dave,
The Ralye STS and the ST need some modification to fit the original sliders and tilting mechanism, as they are about 25 mm off the stock Porsche bolting pattern. If you build your own mounting bracket I gladly supply you with my sliders.Will post later a picture of the Rallye STSmounted into a 914. |
GTS |
Apr 2 2007, 09:52 PM
Hi All,
I heard your questions and suggestions. We just reworking our seat line nd the NEW LeMans will sit even deeper, a bit wider and with the option of sideopenings for the 5-6 point harnesses. The Rallye STS will have additional mounts to fit the 914 sliders-but again won't fit with the rear padding. We will have changes to all our seats, but we will inform you always and here. regards Stefan 702 353 7175 |
dr914@autoatlanta.com |
Apr 9 2007, 02:44 PM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Excellent piece! Reminds me of the old factory recarro seats offered optionally for the 914-6 models! I also like the fact that it just looks so stock that it will pass concours muster.
seanery |
May 4 2007, 01:20 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,846 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
is the revised LeMans available yet? Any pics?
GTS |
Jul 21 2007, 02:22 AM
Hi All,
Finally we are ready to take orders again, it's been too long for our taste. All new steel tube frame seats are now powder coated and have additional safety features which are required by the PCA and SCCA like all seats have openings in the seating and in the side of the frame for routing of the seatbelts through the seat-even the LeMans and Nurburgring models. The LeMans will be a bit wider-still snug but to accomodate more drivers and the headrest will be shorter and less forwarding-Thanks to recommendation from 914ern-but all dimensions stay the same and look wise apart from the headrest the same as the previous models. Now can the Rallye and the Sebring mounted on the stock tilting /slider bracket of the 914 without modification. The Rallye has a more classic sideline and a deeper seating position. We also have 2 more new seats the Avus-looks like a Nurburgring but has the dimensions like the Rallye-fit's as well the 914 sliders and the TransAm which will be a steering wheel problem in the 914's. Prices stay either the same or will be a bit lower but that will be determined once production here in Texas has started-Yes most seats will be Made In the USA and all others like the ST and RSR are Made in Germany-nothing more from Italy except leather and some leatherettes. Will post pictures of all seats once we have made all models. Thank you all for your interest and trust. |
mbdoc |
Jul 21 2007, 07:51 PM
Newbie Group: Members Posts: 24 Joined: 2-December 06 From: Lake Arrowhead CA Member No.: 7,298 |
Setfan
When can we order them? Adrian |
GTS |
Aug 26 2007, 11:11 PM
Hello Adrian and all others,
sorry I was absent here for a long time as the new seats kept me busy 24H... The seats are now ready to be ordered. All come now with the waist belt opening option-if you want it... with additional safety features with a 95% original basket weave-only black for now leather in all colors in basket weav available 5 seats that can be bolted to the original tracks.... And I will be in Ventura to present the new line MADE in the USA ClassicCarSeats.com |
mbdoc |
Sep 2 2007, 11:23 AM
We look forward to meeting you and the great weekend in Ventura.
Adrian |
jim_hoyland |
Sep 6 2007, 10:50 PM
Stephan
See you in Venture, lets see if we can get the color I want. I'm bring a sample Jim |
FlyPorsche |
Nov 20 2007, 03:42 PM
Newbie Group: Members Posts: 2 Joined: 31-August 07 From: Denver, Colorado Member No.: 8,060 |
I got my seat from Craig at Camp914. It is great and your stock belts work just fine. I ran my first AX with the seat installed over the weekend and no problem with my <!-- emo&:bootyshake: -->(IMG:http://www.914world.com/bbs2/html/emoticons/bootyshake.gif)<!-- endemo --> moving in the seat. Thank you for the photo and testimonial regarding stock seat belt fit with this seat. To your knowledge, are there any distributors or retailers of this Le Mans seat in Colorado? |
boxstr |
Nov 25 2007, 09:48 PM
Stefan is in Austin Texas, and I am in Lake Oswego Oregon. I do not know of any in Colorado.
CCL |
Lo-Fi Version | Time is now: 27th April 2024 - 09:49 PM |
