Speaking of dropping engines..., engine dolly advice, etc. |
JeffBowlsby |
Oct 10 2004, 06:11 PM
914 Wiring Harnesses Group: Members Posts: 8,532 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
QUOTE So you loosen the nut on the long rod a little bit on each side until it's on the dolly Yes. It actually goes pretty fast once you get the hang of it. I prefer and recommend it because it is safe and a one-person job. I think its nuts to balance a 500 lb drive train on a single point jack, while steadying it with the other hand, then lower it down about 18 inches, then pull it frm under thew car at least a few feet. There was a special adapter plate that the dealers/factory used to keep their assemblies stable, not just a jack centered under that mass. |
Lo-Fi Version | Time is now: 6th June 2024 - 09:38 AM |
