Replacing the shift coupler bushings |
chris914 |
Oct 9 2004, 12:33 PM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
I'm replacing the bushings that are in the shift coupler on 73 and later. How do I remove the pin that goes through the coupler. bushings, and rod without breaking the coupler. The pin seems rusted in there.
jr91472 |
Oct 9 2004, 01:07 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
you have got to press them out with a vise and a couple of deep sockets. Run a search on this forum for more details.
good luck |
jim912928 |
Oct 9 2004, 01:12 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I was going to attempt the same thing today....but I got under there with my 4mm allen socket and low and behold the pins on both side of the shift bar are rounded out...now what do I do?
machina |
Oct 9 2004, 01:22 PM
QUOTE(jim912928 @ Oct 9 2004, 03:12 PM) I was going to attempt the same thing today....but I got under there with my 4mm allen socket and low and behold the pins on both side of the shift bar are rounded out...now what do I do? drill it out, but do a better job than I did (IMG:style_emoticons/default/smash.gif) Attached image(s) |
SGB |
Oct 10 2004, 07:26 PM
before you drill it out-
Only yesterday I used 4.5 mm socket head type allen wrench to get this done (at the firewall). I slathered the locking bolt with a lot of liquid wrench for a few days prior (while stripping it the rest of the way). I used a big C-clamp to jam the allen socket into the rounded hole. Maybe you can do that too. (IMG:style_emoticons/default/aktion035.gif) |
bondo |
Oct 10 2004, 07:42 PM
QUOTE(SGB @ Oct 10 2004, 06:26 PM) before you drill it out- Only yesterday I used 4.5 mm socket head type allen wrench to get this done (at the firewall). I slathered the locking bolt with a lot of liquid wrench for a few days prior (while stripping it the rest of the way). I used a big C-clamp to jam the allen socket into the rounded hole. Maybe you can do that too. (IMG:style_emoticons/default/aktion035.gif) I've done similar things with torx bits, sometimes it works! (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 07:50 PM |
