Subaru Conversion, Helpful Hints |
Porscharu914 |
May 17 2012, 02:12 AM
Newbie Group: Members Posts: 20 Joined: 17-May 12 From: Denver, Colorado Member No.: 14,439 Region Association: Rocky Mountains |
Recently I was gifted a '71 914. This car was given to me by a member at the country club I work at. In 1983 he took the car to a shop in Nebraska where he paid a guy 4k to do a FULL restoration to the motor and body. ($4000.00 went slightly farther than it would today) The guy was supposed to work on the car on the weekends and they planned the project to take 18-24 months. After the motor/trans were pulled and the body work had been done the shop closed down and the car had to go....NOW. The guy I got the car from picked it up from the shop and stored it, mid restoration, in a garage thinking someday he'd get to it. The car hadn't been touched from then until last 2 Sundays ago and I'm now the proud owner of a primed, motorless, transmissionless, brakeless, and interiorless 914. With all the resources and personal abilities I have I should be able to flip the car in about 2 years....hopefully sooner.
Since the motor and transmission were pulled and mysteriously went 80% of the way missing I've decided to do the somewhat frowned upon Subaru swap. Yesterday I picked up the FWD transmission, yes FWD, out of a 92 Legacy. I'll be going back for an EJ22 (non turbo) on Monday. I'm not worried about mounting the motor/trans or getting CVs that will fit. I'm most concerned about doing an ALL AROUND hub conversion for the sake of saving some $$$ on brakes and the versatility of a wider wheel selection. So with the novel out of the way here are a few of my questions: What hubs will be the best bet for all 4 corners? (consistent bolt pattern is a must) Is plumbing in a front mounted radiator the most effective water cooling solution? Do I need to upgrade the fuel pump? If so, to how many lph? Is there an easy solution to making the Subie conversion work with my guage cluster? (tach, speedo.....etc) Are there any non-mechanical issues I'm up against for bolting everything together? Also I would very much appreciate any added advice or tips to make this a smooth conversion. Cheers |
Porscharu914 |
May 4 2014, 09:54 PM
Finally getting into this project. In the last 2 weeks I've been getting together a lot of stuff. Waiting on several parts right now. Ian over at coldwater914.com is sending an engine cradle to me. I have an American Autowire kit that should be here tomorrow afternoon. Ordered pads and rotors from Pelican Parts. My radiator fans should be here Wednesday/Thursday. Also waiting to find out if I will have the winning bid on an RCI 12 gallon fuel cell. I also picked up a new alternator and radiator.
I'm working on resealing the motor and replacing the timing belt. Motor also got a fresh water pump, plugs and wires. Hopefully I can get the brand new fly wheel and clutch on once I finish the reseal. I'm going to use one of the hoods that I have to make an extractor to help pull air through the radiator. I'm really learning a lot through this experience. Like the carpet out of a 99 Miata fits decently in the 914. Needs a little trimming but for $free.00 I won't complain. My buddy and I are starting to play around with fiber glass in hopes of eventually moving into pulling carbon fiber. Who wouldn't love a set of carbon fiber head light covers? Instead of the white, which gets terribly painted black. I will try to keep anyone posted on how all of this comes along. PM with something you may like to see made out of carbon fiber and maybe in the future we can make it happen. When I get the engine cradle and can put the motor/trans in the car I will begin working on the cable shifter a little more. I'm using the shifter out of an 02? Ford Focus. Took a small amount of modding to get the cables attached, nothing major. Cables came out of a boat and are about 8 feet too long but I can use them for now. Still a lot coming up in the next few weeks. I'll try to get some pictures up soon. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/type.gif) (IMG:style_emoticons/default/piratenanner.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 06:33 PM |
