| IM101 |
May 22 2012, 10:57 AM
Member ![]() ![]() Group: Members Posts: 264 Joined: 9-November 10 From: Boise Idaho Member No.: 12,367 Region Association: Pacific Northwest |
For those who don’t know I’m starting to produce the items necessary for a Subaru conversion. I just got some prototype axles in from Sway-A-Way(SAW) and test fit them last night. While they fit both the older and newer style Subaru transmissions (different axle output style, male or female CV’s) as well as both the 914 and 944 CV’s I have stumbled onto a bit of a problem. The way Subaru designed the later/stronger 2005+ transmissions (with the male DOJ) the hub assembly must be removed to get the axles off. Translated to the 914, it makes installation/removal much more of a hassle than the earlier weaker transmissions.
What I need your opinion on is the viability of the SAW axles, originally at 375$ a set they were meant to be the most inexpensive/universal solution for the axle portion of the Subaru swap. Providing a cheaper alternative to the 600$+ the annoyance of needing to open the 2005+ box up and install the older style male stubs, that Subaru Gears offers. However now with the necessity of the male stubs for the Subaru transmission in the 914 it one of the advantages of the SAW system has been eliminated. It is still less expensive 375 (2004- trans) or 475 (w/stub for 2005+ trans) vs 500$ or 600$. So anyone considering a “suborsche,” let me know what you think, is this something you would be interested in? I am ready to order 10 sets and they would be ready in 2 weeks, just pending your opinions on the matter. Thanks Ian M. |
IM101 New development regarding Subaru axles (group buy maybe?) May 22 2012, 10:57 AM
strawman I truly appreciate your willingness to take on thi... May 23 2012, 12:14 AM
IM101 I believe the biggest challenge you're up aga... May 23 2012, 12:46 PM
IM101 another note, people have asked me several times n... May 23 2012, 12:50 PM
IanJ Ian,
As you know this is something I need to do mo... May 23 2012, 06:12 PM
IM101 Wow Ian, that will be a stout transmission, the RA... May 24 2012, 01:37 AM
Lennies914 I'm on board with what you are doing. Unless t... May 27 2012, 10:12 AM
thenewwazoo I am interested in this, but I am emphatically not... May 27 2012, 10:56 AM
IM101
I'm on board with what you are doing. Unless ... May 29 2012, 11:26 AM
dangerranger01 Any updates? I plan to do a subaru swap once i fin... Jul 17 2012, 09:21 PM
IM101 Things have been going slow, but are ticking up ag... Jul 17 2012, 11:33 PM
thenewwazoo Any news? All this buying other people xmas presen... Dec 22 2012, 08:56 PM
blitZ I'm looking to get the entire kit, including a... Dec 22 2012, 10:50 PM
IM101 Spoke with Sway-A-Way, they said the axles have be... Dec 25 2012, 09:08 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:38 AM |
