seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
Title says it all, anyone ever do an oil cooler in the front passenger fender well like a 911? If so, got pics, results, etc?
Thanks! And....if this has been discussed while I was away please just direct me to a linky. (IMG:style_emoticons/default/smile.gif) |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
You gonna drill the front fender for air flow like the 911?
seanery |
I've been reading about the brass coolers used from 80-84, Bruce Anderson says that they dont need a lot of air flow to work. Especially compared to the trombone cooler. Thoughts?
hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
My LE had one mounted in the passenger side rear fender when I got it.
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
Haven't done it but thats my plan. My 2.4 is small and I figure the loop cooler should keep temps in check.
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
I've always heard that the trombone type coolers had as much calling from the lines running up the side of the car, and the loop was mainly there to bring it back to the engine. Also, the 911 fender well is much more open than that found in a 914.
seanery |
I've heard the same George, I'm interested in the brass coolers fitted in the fender well only used in US 83-84 and Euro 80-84 cars.
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I would think that adding a vent/passage behind the fog lights would make this effective. I've always thought that the front fenders, under the turnsignals and/or headlights would be suitable, if done right. (IMG:style_emoticons/default/idea.gif)
krk |
Senior Member ![]() ![]() ![]() Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 ![]() |
I've been reading about the brass coolers used from 80-84, Bruce Anderson says that they dont need a lot of air flow to work. Especially compared to the trombone cooler. Thoughts? I don't have too much to add. Some time back, I did an engine/tuneup class with BA -- he said pretty much exactly that. I have a 76 turbo carrera that came with the trombone -- the engine temps were barely acceptable in motion, and in a CA summer, at idle quickly go way too high. I swapped the trombone for a fan-driven radiator and the temp-life has been pretty good. If I didn't want to molest the front, I'd definitely be doing something to get more air in there tho. hth. --krk. |
jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
I'm considering the same cooler for my 3.2....been considering passenger front and rear wheel wells...keep the thoughts coming!
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
Hard lines do give off a lot of heat in addition to the cooler, but which cooler to use will depend on the engine. For 2.4L and above I'd not use anything short of the tube cooler and a 3.6 needs a "monster" because of the deletion of the engine cooler.
I have the tube cooler (can't remember the row count) from my '84 and I'll bring it to the 914 and see if it'll fit up there. 914's aren't as tall up there as the 911 is but it may work at a different angle. I'll shamelessly state it's for sale. PM me if interested. Somebody may able to answer this before I can get to it early next week. I'll post if this isn't answered by then. Good luck Edit: Another thought, ignore if off-topic. To position... There is a ton of space ahead of the right rear tire. I'm probably gonna put my transaxle oil cooler there and perhaps the auxiliary engine cooler too as it's getting beat up on the rear of the car. I know, the weight should go up front but I like short hoses. |
zig-n-zag |
Member ![]() ![]() Group: Members Posts: 206 Joined: 18-May 06 From: Hawaii Member No.: 6,024 ![]() |
I'll be using a 28-row brass oil cooler to cool my type 4.
Dimensions are about 4"x7-1/2"x19." Fins are around 1-1/2" wide. And the cooler weighs some 8-1/2lbs. I held it up in the front driver's side wheel well behind the blinker just to get an idea. It's cramped in there. Not impossible tho. |
Lo-Fi Version | Time is now: 1st July 2025 - 02:02 AM |
