SS brake Lines Help!!!!!!, Installing |
Mike Wofford |
May 10 2003, 12:20 PM
Member Group: Members Posts: 68 Joined: 29-April 03 From: Olympia, Wa. Member No.: 629 |
(IMG:style_emoticons/default/confused24.gif) Is there an adapter need to go from the line to the caliper. what is the transition. Any help or info much appreciated.
Thanks Mike (Dazed and Confused) : (IMG:style_emoticons/default/beerchug.gif) |
tahoward |
May 10 2003, 07:42 PM
Member Group: Members Posts: 87 Joined: 30-December 02 From: Middletown, OH Member No.: 52 |
The calipers attach to a solid metal line and then to a rubber line. The stainless lines replace the rubber lines and are the same size and with identical fittings. Hope that helps. (IMG:style_emoticons/default/rolleyes.gif)
Mike Wofford |
May 10 2003, 10:07 PM
tahoward
Thanks, thats the help i was looking for. I should have done a better job of looking at the existing lines. |
Lawrence |
May 11 2003, 08:43 AM
Welcome to the group, Mike!
It's a nice and easy install. Recommend you soak the fittings in penetrating oil for a day. Be sure to use real line wrenches. Both of those things will make the job easier. And as Mike Ginter recently reminded me - use a pair of vice grips to R&R the retaining clips. -Rusty |
Lo-Fi Version | Time is now: 20th May 2024 - 06:35 AM |
