Mike Wofford
May 10 2003, 12:20 PM
Is there an adapter need to go from the line to the caliper. what is the transition. Any help or info much appreciated.
Thanks
Mike (Dazed and Confused) :
tahoward
May 10 2003, 07:42 PM
The calipers attach to a solid metal line and then to a rubber line. The stainless lines replace the rubber lines and are the same size and with identical fittings. Hope that helps.
Mike Wofford
May 10 2003, 10:07 PM
tahoward
Thanks, thats the help i was looking for. I should have done a better job of looking at the existing lines.
Lawrence
May 11 2003, 08:43 AM
Welcome to the group, Mike!
It's a nice and easy install. Recommend you soak the fittings in penetrating oil for a day. Be sure to use real line wrenches. Both of those things will make the job easier.
And as Mike Ginter recently reminded me - use a pair of vice grips to R&R the retaining clips.
-Rusty
