Fuel Pump issue?, having trouble with my 914-6 |
shepmon |
Oct 12 2004, 07:40 PM
Newbie Group: Members Posts: 5 Joined: 25-February 04 From: Rocky River, Ohio Member No.: 1,717 |
Hi, I think my factory 914-6 might need a new fuel pump. How does one know? My car is now very hard starting. I need to pump the gas a lot to keep it running. It takes a lot of turning over to get it to fire. It's missing, backfireing and losing power under stress (going up hill). Virtually undriveable because I live at the bottom of a hill. I checked and the fuel is pumping gas when I turn the key. It has a fairly new perma tune cd box (5 months old). I suspected that the coil needed to be replaced because it looked original. So it has a new coil. It sort of seems like an ignition problem but I'm really not sure. It doesn't seem to be firing right. This came on suddenly. At first I though I had just flooded it. Any thoughts would be appreciated. shep
Oct 12 2004, 07:50 PM
Resident German Group: Admin Posts: 41,611 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
to be sure about the pump, you'll need to get a fuel-pressure gauge and see where you pressure is at when the pump is running ...
if you suspect fuel starvation, that would be a place to start. could also be a clogged fuel filter or the jets are clogged ... i'm not a carb guy, so others hoepfully will chime in here ... (IMG:style_emoticons/default/wink.gif) Andy |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:05 PM |
