suspension |
suspension |
73p914 |
Oct 12 2004, 10:03 PM
Member Group: Members Posts: 50 Joined: 12-October 04 From: san antonio, tx Member No.: 2,932 |
i want to lower my suspension an inch and a half or two inches all the way around but i dont understand the lbs. 100lbs,140lbs,200lbs etc.... could someone explain pleeze.. (IMG:style_emoticons/default/ar15.gif)
Mueller |
Oct 12 2004, 11:48 PM
the pound ratings of the springs have almost nothing to do with lowering the car........with the stock parts, you can darn near have the car sitting on the ground (it'll handle like cr@p, but it'll look neat (IMG:style_emoticons/default/smile.gif) )
what are you trying to do? (daily street driver, agressive auto-x or????) are new rims/tires in the picture? front: re-index the torsion bars (do a search here for torsion bars, this has been covered a whole bunch of times) rear: best bet is to get some "real" shocks such as Bilsteins or even better yet, Koni Yellows and put on adjustable spring perches (search here for pictures, vendors) |
bob91403 |
Oct 13 2004, 12:42 AM
Senior Member Group: Members Posts: 618 Joined: 15-September 04 From: Los Angeles, CA Member No.: 2,763 |
According to Pelican Parts the 100lb springs will give you a stock ride height or higher, and, the others will lower the car. Add adjustable bilsteins and you can tweek it anyway you like. Adjust torsion bars for the front.
73p914 |
Oct 13 2004, 07:11 AM
im going for agressive street and i have the 8 spoke rims and i want it to not only look good but perform good also
d914 |
Oct 13 2004, 07:18 AM
Advanced Member Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
140-150lbs springs in the back will drop the rear end an inch to inch an a half.
adjust the torsion bars in the front. adjustable shocks would be good. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:16 PM |
