motor mount removal, any tips? |
tommy914 |
Oct 12 2004, 11:24 PM
Life is a journey, enjoy every turn. Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None |
I was just finishing up putting all the pieces on the front of the motor after re-sealing my oil pump, when I stripped the threads on one of the motor mounts. (IMG:style_emoticons/default/headbang.gif)
Is there any way to get the motor mounts off without removing the fan shroud again!?? I can't seem to get a socket on there and have enough room to loosen the nuts. (IMG:style_emoticons/default/mad.gif) I'm real close to selling this thing and buying something that I can drive more than I work on it. |
Bruce Allert |
Oct 13 2004, 06:48 AM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
QUOTE(tommy914 @ Oct 12 2004, 10:24 PM) I'm real close to selling this thing and buying something that I can drive more than I work on it. I've been there........ Just recently (IMG:style_emoticons/default/smile.gif) cuz there's better times ahead. Small open end & box end wrenches along with 1/4" drive sockets will fit (barely) and you oly get a slight amount of turn each time. With the engine out it's easier than with it in and I've done both however there's still not enough room to work but it can be done. Also, if you have a universal joint style extension you can sometimes contort it to work. If the mount is stripped it might not unscrew so try cutting through the rubber with a small bladed hack saw and you can just pull the nut/bolt out. ......b |
Oct 13 2004, 09:58 AM
Resident German Group: Admin Posts: 41,612 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(tommy914 @ Oct 12 2004, 10:24 PM) I can't seem to get a socket on there and have enough room to loosen the nuts. (IMG:style_emoticons/default/mad.gif) brad insists it can be done with the shroud on, but i couldn't manage to get a wrench or socket on there either. for me, the solution was shroud-removal ... (IMG:style_emoticons/default/smash.gif) Andy |
Root_Werks |
Oct 13 2004, 10:01 AM
Village Idiot Group: Members Posts: 8,312 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I replace my broken 4cyl mounts with 6cyl engines. Problem solved. (IMG:style_emoticons/default/biggrin.gif)
tommy914 |
Oct 13 2004, 01:17 PM
QUOTE(Root_Werks @ Oct 13 2004, 11:01 AM) I replace my broken 4cyl mounts with 6cyl engines. Problem solved. (IMG:style_emoticons/default/biggrin.gif) Sounds like a good idea. I'll see if the wife will buy it. "yes dear, I broke the engine mount, so I'll need a whole new engine, and I need to upgrade to the 6 cyl since it has more safety features (as in it will get me out of the way of that SUV faster)" |
ematulac |
Oct 13 2004, 02:13 PM
914 addict Group: Members Posts: 540 Joined: 24-November 03 From: Palmdale, CA Member No.: 1,382 |
I had a similar problem this past weekend.
My motor mounts had both sheared in half. The bottom halves were easy to remove, but the top halves were a bitch. On the driver's side I removed the warm air guide to give me enough room to get a socket on the mount. I could only move the ratchet about 1 click or so each turn, so it took a while. But yeah, it can be done. As for the other side, I drained the oil and removed the oil filter and was able to remove that one as well. This little 10 minute jobe took a lot longer than expected, but it was worth it. Hang in there with the 914. When I feel like giving up on the darned thing I just take it for a drive and all is well again. (IMG:style_emoticons/default/wub.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:18 AM |
