rear susp. question |
Aaron Cox |
May 10 2003, 04:49 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
hi guys, back from my week long lurking experience....
any way. i got my 140 lb welt. springs and my bilstein adjustable perch shocks now. next weekend is install day. *what perch setting should i use? *do i need a spring compressor? *what's all this about tie-wrapping the spring into the perch? *top or bottom perch? can you guys help me out? n e 1 been there done that? (IMG:style_emoticons/default/huh.gif) |
ChrisReale |
May 10 2003, 06:01 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
I guess give it a shot, and if you need a spring compressor, go rent one! I have no experience with 140# springs. I recall reading that you dont need one. The reason the spring comes out, is because of gravity. When you have the rear on jack stands, the trailing arm lowers, as does the shocks. Once the shocks are at a maximim length, the spring just comes down with the lower seat, because the length of the extended shock is longer than the spring. Sometimes they do re-seat themselves, sometimes they dont.... I say start with the middle spring perch slot.
Lo-Fi Version | Time is now: 19th May 2024 - 12:58 PM |
