| Eric_Shea |
May 28 2012, 06:14 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Love soda... (IMG:style_emoticons/default/confused24.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-a.akamaihd.net-1110-1338250463.1.jpg) Neutralized with a vinegar spray bottle. Smelled like a Greek salad for a couple days. $500.00 Amazing results: (IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-a.akamaihd.net-1110-1338250465.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-a.akamaihd.net-1110-1338250465.3.jpg) |
| Dr Evil |
May 28 2012, 06:41 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
"Love soda"?
That just sounds gross. |
| Dr Evil |
May 28 2012, 06:47 PM
I see that the soda revealed a gorilla face under the paint and rust (IMG:style_emoticons/default/blink.gif)
| snakemain |
May 28 2012, 07:05 PM
Ronin Member ![]() ![]() ![]() Group: Members Posts: 583 Joined: 14-January 10 From: Aviano, Italy Member No.: 11,232 Region Association: None
So when can I bring my car by?
| Eric_Shea |
May 29 2012, 12:27 AM
QUOTE I see that the soda revealed a gorilla face under the paint and rust We know you shouldn't weld. We're probably fairly certain you shouldn't be doctoring. We're more than certain you shouldn't be drunk posting. |
| MDG |
May 29 2012, 05:27 AM
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
QUOTE I see that the soda revealed a gorilla face under the paint and rust We know you shouldn't weld. We're probably fairly certain you shouldn't be doctoring. We're more than certain you shouldn't be drunk posting. Agreed, Erc. Besides, that's obviously a Hippo NOT a Gorrila. |
| scotty b |
May 29 2012, 06:21 AM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
I bet you could set up a 2nd business with this new blasting. Have them drive down or trailer, blast the car and drive home the same day. Hire someone at $20/hour and charge owner less than soda blasting. Wonder how well it does on boats? That's the idea (IMG:style_emoticons/default/smile.gif) And it does vey well on boats, the company actually has video of it stripping a fiberglass boat, and aanother showing a pretty corroded steel boat trailer |
| Dr Evil |
May 29 2012, 06:39 AM
QUOTE I see that the soda revealed a gorilla face under the paint and rust We know you shouldn't weld. We're probably fairly certain you shouldn't be doctoring. We're more than certain you shouldn't be drunk posting. Agreed, Erc. Besides, that's obviously a Hippo NOT a Gorrila. Bull shit! Look at the nostrils and lack of ears. It is most definitely a cartoon gorilla face. And Erc, I was sober. I dont need alcohol to release my inner creativity.....just enhance it from time to time (IMG:style_emoticons/default/tongue.gif) |
| effutuo101 |
May 29 2012, 01:58 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,738 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
800 including pick up and delivery for body and 4 doors. (2 doors for Jon B.)
| Bartlett 914 |
May 29 2012, 02:07 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Soda is the only way to go. Better than nuts and way better than sand. Low heat, no mess. I have heard quote for a 914 in soda in this area for $2k. Soda is total b.s. First off it won't do jack to rust or bondo, second, once the car is blasetd it needs to be washed and preferably sanded otherwise the primer will not stick to the car. This was first apparent in the airline industry when planes were being soda blasted and repainted and the paint started peeling off within a couple months. Most primers ( definitely the one I use ) have an acid in them to etch into the base metal, soda does not etch into the metal mechanically, and is a base substance ergo the two do not mix. I do not and will not use soda, I have personally seen it fail twice and both times was done by a business that speicialized in it. The process I am looking at is the new solution to soda. As I said, it generates zero heat, uses glass as the media, and leaves the surface ready for immediate priming. This process also has no dust, leaves no residue, and can be done within 10 feet of another car and will not harm or sully it in any way. (IMG:style_emoticons/default/smile.gif) Pending price this is THE best setup I have found So the system is not soda. It uses glass and leaves no residue? The glass must go somewhere. The only other system I can think of uses dry ice and that I don't think works on rust. What is this system? |
| d914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,350 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
soda about $1200
sand I have heard can be pretty cheap $500-750 Soda was our best alternative to date. yes a good acid wash was needed. The up side the soda did lend a hand in holding off flash rust as an issue. My car sat naked in the basement for a good time to no ill effect except were we handled it. |
| OU8AVW |
May 29 2012, 02:35 PM
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,804 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
Gorilla? Um, did you guys notice the "other" thing that showed up on Eric's car post soda blasting?
| scotty b |
May 29 2012, 02:42 PM
Gorilla? Um, did you guys notice the "other" thing that showed up on Eric's car post soda blasting? ![]() That would explain Erc's personality issues (IMG:style_emoticons/default/dry.gif) |
| Dr Evil |
May 29 2012, 02:47 PM
That dude hangs out outside of the 7-11 and asks for change. Weird seeing him there.
| OU8AVW |
I was referring to the Savior's image, not the penis shape at the bottom.....
Sicko.... Attached image(s)
| Dr Evil |
May 29 2012, 02:54 PM
Penis????
| MDG |
May 29 2012, 04:21 PM
| plas76targa |
May 30 2012, 06:38 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
attempting to wrestle this back on track for Scotty... I saw this system this past weekend, was either an infomercial or another show on the speed channel. Uses glass beads and a waterbased solution. IIRC the 'water' includes anti rust chemicals to help prep the metal. Or something like that.
| Cairo94507 |
May 30 2012, 06:47 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,611 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I am kind of interested here as my car is at Scotty's and may be one of the first subjects since my car is going to be media blasted....just don't know what with now.
BTW, all of the cars I have heard of getting media blasted, go from $750 to $1,200 complete and some included primer afterwards. THat included muscle cars and P-cars. |
| Bartlett 914 |
May 30 2012, 08:17 AM
attempting to wrestle this back on track for Scotty... I saw this system this past weekend, was either an infomercial or another show on the speed channel. Uses glass beads and a waterbased solution. IIRC the 'water' includes anti rust chemicals to help prep the metal. Or something like that. Interesting (IMG:style_emoticons/default/popcorn[1].gif) I saw a system that uses sponges. It has the abrasive imbedded. The sponges absorbs the dust after impact. |
Lo-Fi Version | Time is now: 14th April 2026 - 07:34 PM |
