Alternator belt removal and running the engine |
biosurfer1 |
May 28 2012, 12:22 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
I'm finally getting around to checking a noise I had throughout WCR. I want to take the alternator belt off and run the engine to find out if it's the bearing or not. How long can I run the engine with the belt off? Can I drive a bit without damaging something?
ldsgeek |
May 28 2012, 01:05 PM
Member Group: Members Posts: 155 Joined: 27-June 10 From: New Hampshire Member No.: 11,885 Region Association: None |
If it's a T4, you can run it til the battery quits. The fan is on the crank, the belt just runs the alternator. Driving it would be OK as long as you get home before the battery dies (or have AAA on speed dial).
biosurfer1 |
May 28 2012, 03:12 PM
Thanks, that's what I figured but wanted to make sure I wasn't missing something
shoguneagle |
May 28 2012, 03:40 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
You will get about 70 miles with the lights on, etc. before the battery quits. Driving during the day only and everything possible off, you get about a week or more.
How do I know???? Steve |
Lo-Fi Version | Time is now: 18th May 2024 - 12:12 AM |
