73 2.0L DJet Part-Out |
rwilner |
May 31 2012, 06:31 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
For Sale: DJet electronics part-out. Reason for sale: I converted to microsquirt.
All parts pulled from my functioning 73 2.0L or purchased as a functioning spare except where noted. All prices OBO -- if you feel a price is off (even way off) make an offer on one piece, multiple pieces, or the whole lot, don't be shy. Add $10 per piece for shipping. Paypal preferred but I can wait for a check/money order if that's your preference. Please PM me as opposed to replying to this post, for some reason I can't subscribe to threads after the site came back up. I'll be checking in regularly though. Here's the stuff-------------------------------------------------------------------------- 1] CHT sensor 0 280 130 017 with OEM wehrle resistor: $100 Nearly brand new, these were NOS pieces I installed on my car for a month or two before my conversion to microsquirt. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-11530-1338467504.1.JPG) 2] CHT sensor 0 280 130 017: $50. Read ~ 1.5k ohms at room temperature. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh6.googleusercontent.com-11530-1338467505.2.JPG) 3] CHT sensor 0 280 130 017: $50. Read ~ 1.5k ohms at room temperature. Includes a resistor that reads 500 ohms...? (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-11530-1338467505.3.JPG) 4] ECU, wiring harness, mounting brackets 0 280 000 037: $100. All connectors are there, idle knob works as it should. The harness is usable but I would give it a good cleaning and inspection before installing. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-11530-1338467506.4.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh5.googleusercontent.com-11530-1338467507.5.JPG) 5] TPS 0 280 120 032: $50. The PO purchased and installed this board NOS about 10k miles ago, includes cover. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-11530-1338467507.6.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh5.googleusercontent.com-11530-1338467508.7.JPG) 6] Starter cable: $10. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-11530-1338467509.8.JPG) 7] Ignition harness: $50. Fully functioning, all connectors are there including OEM bullets for the reverse light. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-11530-1338467509.9.JPG) 8] Cold Start Valve: $35 I *think* this works but never tested it separately from the rest of the system. My car started well in the frozen north though! (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-11530-1338467509.10.JPG) 9] Green top fuel injectors 0 280 150 019: $80/ea or $300/all. These worked fine in my car. I had no leaks, but if I were reusing them i'd replace the fuel hose elbows but I had no leaks. **If you buy all 4 i'll include new tip seals and new body seals** (IMG:http://www.914world.com/bbs2/uploads_offsite/lh5.googleusercontent.com-11530-1338467509.11.JPG) 10] Decel Valve 0 280 160 108: $30. Works, could use a cleaning. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh5.googleusercontent.com-11530-1338467510.12.JPG) 11] Anti-Flashback valve: $20. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-11530-1338467510.13.JPG) 12] CHT sensor 0 280 130 012: $10. Installed and then uninstalled before it was used, no washer though. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh5.googleusercontent.com-11530-1338467510.14.JPG) 13] 3 AARs: $20/ea or $50/all. Untested but I believe they all work. I only took a pic of one of them but they all are in the same condition as the one pictured -- wires are intact. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh5.googleusercontent.com-11530-1338467510.15.JPG) |
Lo-Fi Version | Time is now: 25th May 2024 - 06:02 AM |
