For Sale: DJet electronics part-out. Reason for sale: I converted to microsquirt.
All parts pulled from my functioning 73 2.0L or purchased as a functioning spare except where noted.
All prices OBO -- if you feel a price is off (even way off) make an offer on one piece, multiple pieces, or the whole lot, don't be shy.
Add $10 per piece for shipping. Paypal preferred but I can wait for a check/money order if that's your preference.
Please PM me as opposed to replying to this post, for some reason I can't subscribe to threads after the site came back up. I'll be checking in regularly though.
Here's the stuff--------------------------------------------------------------------------
1] CHT sensor 0 280 130 017 with OEM wehrle resistor: $100
Nearly brand new, these were NOS pieces I installed on my car for a month or two before my conversion to microsquirt.
2] CHT sensor 0 280 130 017: $50.
Read ~ 1.5k ohms at room temperature.
3] CHT sensor 0 280 130 017: $50.
Read ~ 1.5k ohms at room temperature. Includes a resistor that reads 500 ohms...?
4] ECU, wiring harness, mounting brackets 0 280 000 037: $100.
All connectors are there, idle knob works as it should. The harness is usable but I would give it a good cleaning and inspection before installing.
5] TPS 0 280 120 032: $50.
The PO purchased and installed this board NOS about 10k miles ago, includes cover.
6] Starter cable: $10.
7] Ignition harness: $50.
Fully functioning, all connectors are there including OEM bullets for the reverse light.
8] Cold Start Valve: $35
I *think* this works but never tested it separately from the rest of the system. My car started well in the frozen north though!
9] Green top fuel injectors 0 280 150 019: $80/ea or $300/all.
These worked fine in my car. I had no leaks, but if I were reusing them i'd replace the fuel hose elbows but I had no leaks.
**If you buy all 4 i'll include new tip seals and new body seals**
10] Decel Valve 0 280 160 108: $30.
Works, could use a cleaning.
11] Anti-Flashback valve: $20.
12] CHT sensor 0 280 130 012: $10.
Installed and then uninstalled before it was used, no washer though.
13] 3 AARs: $20/ea or $50/all.
Untested but I believe they all work. I only took a pic of one of them but they all are in the same condition as the one pictured -- wires are intact.
