Parts Heaven swap meet this weekend 6-3-12, Who's going? |
Mike Bellis |
May 31 2012, 09:52 PM
I'm going! (IMG:style_emoticons/default/biggrin.gif)
Al asked me to bring the rotary and show it off. Little does he know I \';m pulling the motor soon. http://www.partsheaven.com/Articles.asp?ID=249 |
Lennies914 |
May 31 2012, 10:00 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
I'm going. I need to show Al the car I bought from him. (IMG:style_emoticons/default/biggrin.gif)
Elliot Cannon |
May 31 2012, 10:16 PM
I'll see you there. I'll be bringing this one with a big FOR SALE sign on it.
JStroud |
May 31 2012, 10:38 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
kkid |
May 31 2012, 10:41 PM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
I'm going, too!
shoguneagle |
Jun 1 2012, 01:40 AM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
One of the great events I miss since moving from California is this car show and parts swap. I always see friends that that have not seen for long periods of time. I have been and sold three times since moving to Arizona. Really miss seeing what parts are available.
Attend if you can; great friends and parts!!! Steve |
smj |
Jun 1 2012, 01:54 AM
"Dude, Steve from Berkeley." Group: Members Posts: 591 Joined: 28-August 05 From: Berkeley, CA Member No.: 4,691 Region Association: Northern California |
Not sure if I'll risk driving the -6 down given the recent half shaft excitement, but I do plan on heading down there one way or another. Only six or seven years late for my first time... (IMG:style_emoticons/default/dry.gif)
Cairo94507 |
Jun 1 2012, 06:53 AM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I will be there probably around 11:00.....hopefully.
Michael N |
Jun 1 2012, 09:29 AM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
I will be there. (IMG:style_emoticons/default/biggrin.gif)
JimN73 |
Jun 1 2012, 01:54 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
I'll be there with a short shopping list:
Nice drivers side rocker panel "pins" for lower rear shock mount without swaybar knobs threaded collars for yellow konis 4 dogbones See you Sunday |
Randal |
Jun 1 2012, 02:07 PM
I'll be there with a short shopping list: Nice drivers side rocker panel "pins" for lower rear shock mount without swaybar knobs threaded collars for yellow konis 4 dogbones See you Sunday I'll have a couple of the gold threaded adjusters there if that helps. Also have a few helper springs. |
MartyYeoman |
Jun 1 2012, 02:09 PM
Senior Member Group: Members Posts: 1,519 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
I'm in.
JimN73 |
Jun 1 2012, 02:26 PM
I'll be there with a short shopping list: Nice drivers side rocker panel "pins" for lower rear shock mount without swaybar knobs threaded collars for yellow konis 4 dogbones See you Sunday I'll have a couple of the gold threaded adjusters there if that helps. Also have a few helper springs. Maybe, Randal. I was looking at the Tarrett Racing 'coil over conversion kit' which includes the threaded collars and upper spacers. I'm using 140 pound springs and the site says that I don't need helpers til I get to 150. Don't know if I need the upper spacers as it probably depends on how long the springs are. I'll jack the car up and measure and add a bit in case they're still compressed. Do you have any insights? Thanks, Jim |
JStroud |
Jun 1 2012, 02:49 PM
I'm still planning on going, but it looks like I'll be driving the Boxster. Took the 914 to Roseville today to mow my daughters lawn, was running hot all the way home. The hotter the weather gets the hotter it's been running. Time to pull the motor and put in the new one.
Jeff |
Randal |
Jun 1 2012, 05:41 PM
I'll be there with a short shopping list: Nice drivers side rocker panel "pins" for lower rear shock mount without swaybar knobs threaded collars for yellow konis 4 dogbones See you Sunday I'll have a couple of the gold threaded adjusters there if that helps. Also have a few helper springs. Maybe, Randal. I was looking at the Tarrett Racing 'coil over conversion kit' which includes the threaded collars and upper spacers. I'm using 140 pound springs and the site says that I don't need helpers til I get to 150. Don't know if I need the upper spacers as it probably depends on how long the springs are. I'll jack the car up and measure and add a bit in case they're still compressed. Do you have any insights? Thanks, Jim If you can find the threaded tube and the tops somewhere, at the event, I think I have the other bits. Much more cost effective than buying new stuff as it's expensive. As to helper springs I've always run heaver stuff, so always used them. (IMG:style_emoticons/default/dry.gif) By the way I might bring a bunch of 8" and 10" springs if that helps. |
JimN73 |
Jun 1 2012, 05:58 PM
Randal, I did some measuring and found that the outside diameter of the sprint is 4 1/4 inches so the perch has to be able to handle that. The springs are at least 12 inches long - probably closer to 14 when not loaded. Also, the shock is only 2 inches in diameter.
I'll be there about 8 on Sunday and will park in the designated area and will look for you. Look for my Yellow is Fastest tshirt Jim |
Krieger |
Jun 1 2012, 07:22 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I'm going. I'll be passing out flyers for The Petaluma Swap Meet I'm promoting!
Michael N |
Jun 2 2012, 09:38 PM
Reminder bump.....
smj |
Jun 3 2012, 02:31 PM
Missed it - looking forward to hearing about some great finds/bargains.
Cairo94507 |
Jun 3 2012, 02:55 PM
Wow, lots of nice cars and tons of parts. I was just eye-balling everything since I have a child in VA getting some work done.... (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 17th May 2024 - 04:24 PM |
