Sound Options? |
Sound Options? |
Alphaogre |
Jun 1 2012, 01:07 PM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
I just picked up a 1970 914-4 (my first) I trying to gather some general stuff to start the rebuild. I am looking for some sound options, and examples. I can weld and fabricate so I was thinking of making my own (i have done it before for other cars) but I am having some trouble finding some good references to what muffler or configuration would work best for these 914's.
It came with dual Webbers already on it, and what is on it seems louder then i would have expected but im looking for the old air cooled throtie sound...if that makes any sense. Obviously the 6's sound great but what options are out there for the 4's? any help would be greatly appreciated. P.S. Also looking for shock/suspension options (looking to upgrade to coil overs to lower and firm up the stance, also looking for good front and back fiber glass bumpers as well. |
falconfp2001 |
Jun 1 2012, 01:20 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I've always liked Elephant Racings packages here
http://www.elephantracing.com/suspension/c...loversleeve.htm And Tarret Engineering as well. http://www.tarett.com/items/914-products/9...prings/list.htm The 914 suspension is pretty versatile but lowering the front can create problems if you don't do it right. Consider a bump steer kit if you lower the front more than 1/2" because your geometry will change a lot. If you do lower it post pics of your progress. |
VaccaRabite |
Jun 1 2012, 02:55 PM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Dual webbers are LOUD in a 914, being that they are right behind your ears and the cabin tends to act like a drum, especially with the top on.
There are carb silencers that are commercially available but expensive. Members have made silencers and or modified bug or 912 air filter housings to do the same. Zach |
Elliot Cannon |
Jun 1 2012, 03:43 PM
I've always liked Elephant Racings packages here http://www.elephantracing.com/suspension/c...loversleeve.htm And Tarret Engineering as well. http://www.tarett.com/items/914-products/9...prings/list.htm The 914 suspension is pretty versatile but lowering the front can create problems if you don't do it right. Consider a bump steer kit if you lower the front more than 1/2" because your geometry will change a lot. If you do lower it post pics of your progress. (IMG:style_emoticons/default/agree.gif) Good advice. As far as noise is concerned. I use these a lot. I also have dual Webers and these work great for engine noise but I use them mostly to stop road noise from other vehicles. If you have a radio in your car and use these they will actually allow you to hear the music better. Attached image(s) |
Harpo |
Jun 1 2012, 03:51 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
What is a carb silencer?
Thanks David |
VaccaRabite |
Jun 1 2012, 05:05 PM
Think an airbox similar to the 911 carb air boxes. They house the filter and also muffle the roar that carbs make.
falconfp2001 |
Jun 1 2012, 08:12 PM
He is talking about something like this. Webers create loud sonic pulses. The only way to make them quieter is to encase the top part of the weber in some kind of intake plenum that provides more divergent angles. That is why the FI engines are way more quieter. the intake runners are longer and have more angles to divert sonic pulses. Weber carbs are very open and the top filter elements usually enhance the pulse instead of quiet the pulse.
Steve |
Jun 1 2012, 08:21 PM
914 Guru Group: Members Posts: 5,592 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Webers are music!! I used to go back and forth through the Alameda tunnel just to listen to them with the top off. My current 3.2 with stock injection is noise in comparison.
Mike Bellis |
Jun 1 2012, 09:39 PM
rfuerst911sc |
Jun 2 2012, 04:17 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I have a 3.0 six in my GT clone with Weber's and was running the open style K&N billet filter housings and the noise was more than I wanted. Recently picked up a 914/6 OEM air cleaner housing and installed it. Wow what a difference it really made the intake roar much quieter. Find something similiar for your four I'm sure you will be pleased with the results.
Alphaogre |
Jun 2 2012, 11:03 AM
My bad, I wasn't clear I want it loud. It was a good thing when it was louder then I thought. If I put a cage in it down the road the sound would resonate in the tubing anyway. This is going to be a Sunday/ auto cross type car. Hopefully down the road a track car. For right now I'm just looking to get it going and have some performance updates for it. I love the sound of the 6's but with it being a 4 I'm just looking for some sound options to try and get close to that sound.
Lo-Fi Version | Time is now: 22nd May 2024 - 10:58 AM |
