FI Wiring Question |
ThinAir |
May 11 2003, 10:12 AM
Best friends Group: Members Posts: 2,542 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
I'm in the last stages of installing an 73 FI 2.0 engine into my 73 that had a carb engine in it. I've got 3 wires coming out of the FI wiring harness near the coil, but don't know for sure where to put them.
A black/red wire and smaller black wire are "bundled" together with a sleeve. From the Haynes wiring diagram it looks like the black/red goes to coil #15. I can't seem to find the black wire on the diagram. There is also a green wire that comes out of the harness by itself (not bundled like the two above). The only green wire on the diagram goes between the coil & the distro so it's obviously the condensor wire, not the one I've got. Can anyone tell me where these wires go? Also, can you confirm that #1 coil is also the one marked + ? I can't see the number markings at the moment and I can never remember which number goes to which +/- sign. Thanks! |
Lo-Fi Version | Time is now: 19th May 2024 - 08:49 PM |
