FUEL LEAK, need to replace injector? |
CTNL74914 |
Jun 3 2012, 08:56 PM
Newbie Group: Members Posts: 6 Joined: 3-June 12 From: New London, WI Member No.: 14,516 Region Association: Upper MidWest |
first time I've posted on here is over a year but now I need help.
I've got a 74 - 2.0 with original D-jet system and have suddenly developed a fuel leak on #3 injector. All clamps are tight on the fuel feed line and it appears to be seeping fuel between the body of the injector and the plastic (green) part where the wire plugs in. Gas pools up on the tin below it within minutes of startup. Sound common? Also- do I need to park it for fear of fire? Replace injector? Need some opinions. THANKS (IMG:style_emoticons/default/confused24.gif) |
dlee6204 |
Jun 3 2012, 09:08 PM
Its a common problem, you will need to replace the injector. Park it. Don't drive it.
You don't want your car looking like this do you? |
speed metal army |
Jun 3 2012, 09:16 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Yep, new injector time.
CTNL74914 |
Jun 7 2012, 10:34 PM
OK - I ordered a rebuilt injector from AA and installed it today. No more leak but now I have a bad miss- presumably from the #3 cyl which got the injector.
I have rechecked both inj connections on that bank but the miss is still there. What to check next? Can those injectors be tested when pulled from the manifold but still hooked up? Looking for ideas. (IMG:style_emoticons/default/confused24.gif) |
Jun 7 2012, 10:47 PM
You can swap the injectors around and see if the miss follows the injector.
You can pull the injector out of the manifold and stick it in a jar to see it work. You usually have to do both on one side unless you find really small jars. It might be worth unplugging the points wire at the coil just to make sure there's no spark. --DD |
914_teener |
Jun 7 2012, 10:48 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
OK - I ordered a rebuilt injector from AA and installed it today. No more leak but now I have a bad miss- presumably from the #3 cyl which got the injector. I have rechecked both inj connections on that bank but the miss is still there. What to check next? Can those injectors be tested when pulled from the manifold but still hooked up? Looking for ideas. (IMG:style_emoticons/default/confused24.gif) Yes they can. You can search for that. put glass jars...disconnect the dizzy....and measure the output over time...Witchhunter has their output. I don't know off hand. Why do you assume a miss is the injector" |
CTNL74914 |
Jun 7 2012, 11:04 PM
You can swap the injectors around and see if the miss follows the injector. You can pull the injector out of the manifold and stick it in a jar to see it work. You usually have to do both on one side unless you find really small jars. It might be worth unplugging the points wire at the coil just to make sure there's no spark. --DD I am assuming the injector because though it had a slow leak before, it ran pretty good and that is the only thing I changed. Now it has a bad miss and I didn't mess with anything else. |
rhodyguy |
Jun 8 2012, 08:44 AM
did you replace the injector seals? 2 per. do them all. should take 30 minutes or less to do all 4 injectors.
k |
walterolin |
Jun 8 2012, 08:55 AM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
If your fuel ring rubber hoses are old, you should think about replacing them with new high pressure hose while you're in there. Rubber cracks over time, and you are running about 29 lbs on the pressurized side, which can give you dlee6204's result above.
CTNL74914 |
Jun 8 2012, 11:11 AM
JawjaPorsche |
Jun 10 2012, 12:33 PM
Just to make sure, you got a green injector not a yellow one.
benalishhero |
Jun 10 2012, 12:44 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
You can also test the solenoid winding with a multimeter. Ohms test across the two terminals. IIRC these are low impedance injectors, so it should read around 2-4 ohms.
Lo-Fi Version | Time is now: 17th May 2024 - 06:34 PM |
