OT - 1993 RS America, need outer air filter cover |
DonTraver |
Oct 15 2004, 09:29 AM
Senior Member Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
My outer air filter cover has been drilled/opened up for better engine breathing. I need a used outer air filter cover to pass smog here in lovely Calif.
I've tried all the yards in Panorama, etc. Haven't been able to find one. So, thought I'd try here. Anyone got one I can buy from them? Thanks, Don |
dgw |
Oct 15 2004, 09:10 PM
Dennis Winter Group: Members Posts: 553 Joined: 7-January 03 From: Santa Cruz Mountains Member No.: 106 Region Association: Northern California |
Oh.................
No help, but its a great car, had mine for 10 years. (in CA, but haven't screwed with it) |
IronHillRestorations |
Oct 16 2004, 07:17 AM
I think I may have one. What year? You wouldn't have a part number would you??
DonTraver |
Oct 16 2004, 09:37 AM
The part number is 964-110-030-05. It's for the complete air filter housing. I just need the outer cover with the snorkle. Think it's the same at a stock C2 or C4 with the 3.6 liter engine.
Here's a pic of the RSA. (IMG:style_emoticons/default/driving.gif) Thanks for the help. Don Attached image(s) |
dgw |
Oct 16 2004, 10:30 AM
White is a good color. Mine has white wheels though.
See the "What do you drive to work" thread, page 4. http://www.914world.com/bbs2/index.php?act...60entry240304 Whats the advantage of doing this --> "drilled/opened up for better engine breathing" Is this because you track the car? |
Mueller |
Oct 16 2004, 11:07 AM
so did you find any at the wrecking yards pre-drilled?
I've thought about doing this mod to mine, but didn't want to mess up the stock air box. you might be better off finding one to borrow for now... Dennis, it "supposed" to help the motor breath a little bit better, the air filter gets more air instead of it flowing the little opening for the stock filter....I've never seen any numbers to verify whether it works or not....you "hear" the difference from what I understand (IMG:style_emoticons/default/smile.gif) |
DonTraver |
Oct 16 2004, 01:42 PM
Found one pre-drilled at Parts Heaven. Not really sure if you get any more power out of it, but it sure sounds nice. Also dropped the secondary muffler, nice throaty sound now.
dgw |
Oct 17 2004, 10:24 PM
Is it the visual part of the smog check you expect to fail, or does more air cause other issues.
I'll have to try this some time, I've never had a problem with a little more engine noise, Porsche engines sound great. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:29 PM |
