tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
I have tried bleedling my brakes with three different types of bleeders and I have the same issue each time. I can get all the calipers to bleed properly except the passenger rear brake. Using the hand pump type of bleeder, I have pumped the right rear brake for a very long time and I still get bubbles. It never seems to change. I wasn't sure if I had speed bleeders or not so I removed the bleeder and found it was slightly bent (probably from over tightening). I put a new bleeder in and restarted the process- no change. Any ideas? I have not seen any fluid leaks. I have not tried to drive the car yet due to some engine issues. They were rebuilt fairly recently (by me)- is it possibel that I screwed something up? Seems to me that I would see a leak somewhere if I screwed up the rebuild.
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I hate bleeding brakes for just this kind of crap. But you may be sucking air in past the threads which shows up in the line, but isn't really air in the caliper.
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
I hate bleeding brakes for just this kind of crap. But you may be sucking air in past the threads which shows up in the line, but isn't really air in the caliper. (IMG:style_emoticons/default/agree.gif) This was my first thought. Nothing beats the 2 person method where someone pumps up pressure and holds it and then someone quickly opens and closes the bleeder. You get a quick rush of fluid to push along any "stuck" air. And you can tell if any air bubbles come out with the fluid or show up after the bleeder is closed. Jim |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Since the bleeder seal is at the cone, put teflon tape just on the threads to stop air bubbles. OR Buy speed bleeders.
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,097 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
I think that two person method with one stomping that pedal is kind of important. Breaks bubbles loose... (IMG:style_emoticons/default/biggrin.gif)
McMark |
tornik550 |
I tried a variation of the ideas above. I put a small amount of Teflon ptfe paste on the bleeder screw threads. Worked like a charm. Thanks to all.
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Gee, Steve. I could swear that I told you that would happen with the speed bleeders and that I had this same problem (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/poke.gif)
442nd914s |
Member ![]() ![]() Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None ![]() |
To piggy back on this tread......
What is the proper sequence in bleeding? I have read in some technical articles to start with the rear right, rear left, front right left right AND on '73 Clymer publication it start with the outboard left rear inboard left rear, outboard right rear inboard right rear, right front (no dual bleeders), left front. (IMG:style_emoticons/default/screwy.gif) I haven't checked my rears to see if they're dual bleeders, but I know for sure that the fronts are dual. What should I do? (IMG:style_emoticons/default/headbang.gif) |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,908 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Sometimes the front piston in the master cylinder gets hung up in the crud in the master cyl. and does not retract, Not allowing rear brakes to pump up.
mittelmotor |
Member ![]() ![]() Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None ![]() |
Another recommendation for Speed Bleeders. Cheap and simple. Bled my brakes just once after the whole system was drained for the renovation, and the pedal is firm.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,737 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
No mention of you know who's long tube method?
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,437 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I would also make sure you don't have a flex line that is bad and collapsed internally.
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Not a fan of vacuum bleeders over pressure bleeders. Those 7x1 bleeder holes on the caliper won't seal until the valve seat is fully seated on many of these old calipers. Meaning, once it's loose, all sorts of air can leak past the threads causing the vacuum bleeder to look like its constantly pulling air out of the system.
Pressure bleeding is much more betterer... |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Speed Bleeders. (IMG:style_emoticons/default/first.gif)
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I have always used the two person method.
With the 914 rears, I have always used the bleed, drive and brake hard, bleed again method. rich |
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
Trust an old guy on this one. . there is no substitute on the 2 person method. . it always works. . {Unless your GF is helping and she doesn't quite know what 'hold the pedal' means }. .
I go around 3 times after a firm pedal and no air just to be sure it's all new fluid. . I tried vacuum bleeding mine and kept getting getting a small amount of airbubbles on one wheel. . . it was sucking past the threads no matter what I tried. . |
Lo-Fi Version | Time is now: 9th July 2025 - 08:20 AM |
