WAS tops - another GB $will be opening up DEC 17, Updated 11/8/17 |
Mikey914 |
Jun 7 2012, 01:37 AM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'm in the process of getting another run of these together. They prove to be much more expensive to to do one or two of at a time. Regular price is $895.
I need 10 partys that are serious about buying these to get this rolling. I have the tooling so the lead times will be about 3 weeks before product starts shipping. Who's intersted? Attached image(s) |
Steve |
Jun 8 2012, 06:44 PM
914 Guru Group: Members Posts: 5,580 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Is it possible to use the stock latches? I am looking for a stock look on the inside.
Mikey914 |
Jun 8 2012, 08:13 PM
Is it possible to use the stock latches? I am looking for a stock look on the inside. Yes, I made my spacing and the entire substructure to allow for the stock latches. I'll have to double check, but I believe we molded off the late style roof. There is a difference on the latches. Just not having an endless supply of latches I couldn't offer it that way. And the icing on the cake - If you use your own latches you can save $75 |
Steve |
Jun 29 2012, 12:18 AM
Is it possible to use the stock latches? I am looking for a stock look on the inside. Yes, I made my spacing and the entire substructure to allow for the stock latches. I'll have to double check, but I believe we molded off the late style roof. There is a difference on the latches. Just not having an endless supply of latches I couldn't offer it that way. And the icing on the cake - If you use your own latches you can save $75 As far as the top goes, is there any difference between the first gen and the second gen or is it just the latches? Curious if there are any improvements over the first batch you made. |
Lo-Fi Version | Time is now: 9th May 2024 - 08:58 AM |
