Removing the exhaust gas recirc. sys., Any warnings? |
Bob L. |
Jun 7 2012, 08:21 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I just acquired a '76 2.0 motor with the EGR system. It was already disabled/disconnected but still attached. I want to remove all the bits and pieces related to and cap off the air inlet pipes that feed into the heads.
SO... Can I just cap off the stubby pipes in the heads? Do the pipes come out completely? If so how do you plug the holes in heads? Do I want to plug the pipes or holes anyway? They are open now and it runs pretty good. Are there any adjustments I should make to compensate for the system being removed? Thanks. |
AZ914 |
Jun 7 2012, 08:42 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
You can cap the pipes that stick out of the heads. Some people put a ball bearing on top (to seal), then a cap (I think a common pipe cap fits). Another option is to remove the pipes and thread a bolt into the head.
I can find the thread/length, but its on my other PC. (its not common). I've never heard of anyone making an adjustment for it.. but obviously just tinker with the idle/fuel mixture knob if it needs it. |
Jeffs9146 |
Jun 7 2012, 08:52 PM
Check your smog laws first! In CA that would make it not pass!
toadman |
Jun 7 2012, 08:56 PM
Member Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
I just acquired a '76 2.0 motor with the EGR system. It was already disabled/disconnected but still attached. I want to remove all the bits and pieces related to and cap off the air inlet pipes that feed into the heads. SO... Can I just cap off the stubby pipes in the heads? Do the pipes come out completely? If so how do you plug the holes in heads? Do I want to plug the pipes or holes anyway? They are open now and it runs pretty good. Are there any adjustments I should make to compensate for the system being removed? Thanks. When I had my 1976 motor "refreshed" we removed the stub pipes and plugged the holes with threaded caps. We got the caps from Brad Mayeur at 914Ltd.com and they worked great. |
Bob L. |
Jun 7 2012, 09:44 PM
Check your smog laws first! In CA that would make it not pass! (IMG:style_emoticons/default/lol-2.gif) I'm in Texas So I'll cap it off. Probably easier to match the thread size. I looked on 914Ltd.com but no sign of head plugs. I could call but I'm impatient and Home Depot it right here. Thanks guys. |
76-914 |
Jun 7 2012, 09:45 PM
3/8"ips cap. brass, alum, galv, brass or black. remove your extension from the fan hub and if the rubber coupler is good, sell it.
Bob L. |
Jun 7 2012, 09:47 PM
76-914 |
Jun 8 2012, 07:59 AM
Then go to Crump Supply on Rockwood Lane. They have them.
TheCabinetmaker |
Jun 8 2012, 08:51 AM
The stub pipes wiil get in the way of removing the bolts for the intake runners unless you bend them outward, breaking the seal to the head. I replace them with an M10X1.25X40mm bolt.
Bob L. |
Jun 8 2012, 09:02 AM
All right... I'll get the plugs. I'm guessing some red Loctite would be in order. Correct?
Lo-Fi Version | Time is now: 17th May 2024 - 02:45 PM |
