ARP through bolts |
ARP through bolts |
Harpo |
Jun 10 2012, 07:22 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
In preperation for the ARP through bolts what is the new hole size suposed to be? I believe that they are 1/2 bolts so I could simply drill out to 1/2 and rechamphur the holes but I just wanted to check to see what other had done.
Thanks David |
Mark Henry |
Jun 10 2012, 08:19 AM
In preperation for the ARP through bolts what is the new hole size suposed to be? I believe that they are 1/2 bolts so I could simply drill out to 1/2 and rechamphur the holes but I just wanted to check to see what other had done. Thanks David They should just slip in, no drilling required, at least the ones I got from LN didn't need to be drilled. You won't be able to use the vibration do-dads that go between the case halves. Is this a performance engine? They are not really required on anything but track or big Nickies engines. |
wingnut86 |
Jun 10 2012, 12:18 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
David,
I sold Hencar in Arkansas my old Hoffman Machine 2.0 that was race ready. It is setup with the oversized throughbolts, can't remember if I shipped ARP or Racewear with it. If he hasn't built his fire-breathing Dino burner yet, he can measure and take pictures. Henry is here as well as TheSamba. Good luck, Dave B. |
Jake Raby |
Jun 10 2012, 06:49 PM
ARP are 3/8" and drop right in.
Lo-Fi Version | Time is now: 17th May 2024 - 08:52 PM |
