QUOTE(Harpo @ Jun 10 2012, 09:22 AM)
In preperation for the ARP through bolts what is the new hole size suposed to be? I believe that they are 1/2 bolts so I could simply drill out to 1/2 and rechamphur the holes but I just wanted to check to see what other had done.
Thanks
David
They should just slip in, no drilling required, at least the ones I got from LN didn't need to be drilled. You won't be able to use the vibration do-dads that go between the case halves.
Is this a performance engine? They are not really required on anything but track or big Nickies engines.
