Mega squirt Fuel Injection |
drgchapman |
Oct 17 2004, 10:26 AM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
Any input as to how this works with a stock 2.0? Where do I find a vendor? How much better is it? Looking for more power, trying to stay in C street prepared class. Thanks guys, Gary
DNHunt |
Oct 17 2004, 10:44 AM
Megasquirt is do it yourself, meaning you buy a board and components, solder it, program it and tune it. If you like DIY and want to put in the time to learn everything it's great. Otherwise wait just a little while longer and get Kit Carlson's new system. It sounds pretty darn easy and should do a great job with FI and ignition.
I've run Megasquirt for 18 months and it's been great for me. It's performed great and hasn't missed a beat, including several AX's, city and highway driving and a roundtrip to Frisco for WCC 2004. My new engine will get and upgraded version with ignition control and closed loop injection. We really didn't find a lot of extra ponies as I had 80.5 hp at the rear wheels on a 2056 with stock cam. We decided that there wasn't a lot left on the table with the d-jet without changing internals, (cam in particular). We were able to clean up the AFR at less than WOT so I think it drives better but that's pretty subjective. Dave |
fiid |
Oct 17 2004, 01:16 PM
What Dave Said. (IMG:style_emoticons/default/agree.gif)
drgchapman |
Oct 17 2004, 02:19 PM
Pretty cool. Must be smart or something. Way beyond my talent and time. I'll lay for the Kit Carlson version. It'll bolt right up, right?
Thanks alot for the info. Gary |
crash914 |
Oct 17 2004, 06:47 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
It works well, except when you do something stupid......I just fried my relay board cause I thought a bigger fuse would help..... (IMG:style_emoticons/default/laugh.gif)
The web page is http://www.msefi.com It is a good read even if you use the Kit set up.... good luck.herb |
Mark Henry |
Oct 17 2004, 07:57 PM
I have the SDS system, works real good. The big downside is mounting the crank trigger (option) is a PITA
Kit's system will have the advantage of the drop in dizzy. SDS has a great site for info; http://www.sdsefi.com/ |
Mueller |
Oct 17 2004, 11:56 PM
you can purchase pre-built and tested Megasquirt boxes, but then you still need to fabricate your own wiring harness, not too bad, just takes good planning
i ran the 1st version MS on my stock 2.0 a few years ago and it ran great....my newest motor and megasquirt are giving me fits, but I believe it is ignition related which i hope will be rectified when I switch it over to crankfire ignition this week (waiting for some connectors right now) the K/C FI is supposed to be more plug-n-play and would be the way to go....however, one should still learn the hows and whys of how the FI works in order to trouble shoot and tune the motor later on down the road. |
Lo-Fi Version | Time is now: 20th May 2024 - 07:47 AM |
