Still some issues, Oil leak and radiator questions on V8 |
skline |
Oct 17 2004, 10:10 PM
Brad, Levi, or any V8 guys, I wired the radiator fans direct to the battery so when I shut it off, they will continue to run till it cools, should I do it differently? Also, I changed out the oil filter this morning and cleaned the mounting surface with a rag to make sure it was clean and then installed the new filter with the normal light oil around the gasket and cinched it up hand tight. It still flows oil from around the filter. I will get under there agian tomorrow after I get back from work and take a picture of it with the filter removed, maybe you can see something I am not. My throttle cable keeps coming off so I will be changing it out also tomorrow with a new one. Other than that, it starts right up and runs strong. Wont be long now.
DrifterJay |
Oct 17 2004, 10:12 PM
I break stuff... Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
(IMG:style_emoticons/default/wink.gif) just watched the video scott....nice....time to go finish lapping my cylinders....
skline |
Oct 17 2004, 10:13 PM
QUOTE(DrifterJay @ Oct 17 2004, 09:12 PM) (IMG:style_emoticons/default/wink.gif) just watched the video scott....nice....time to go finish lapping my cylinders.... Do it just like I told you and it will be fine. I cant believe you are not done with it yet. Get back to work, I expect to see you driving it to D&G next Sunday. |
DrifterJay |
Oct 17 2004, 10:20 PM
I didnt get home until 740 this evening .....worked 24 hours straight through the night....I am tired...got to drive back to ft irwin again in about 2 hours.... <_<
skline |
Oct 17 2004, 10:22 PM
Jeesh, and you are working on your car? Way to be a die hard. Good luck and dont fall asleep on the way there.
JB 914 |
Oct 17 2004, 10:24 PM
Daddy! Finish my car NOW!!! Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 |
Jared,
Let me know if you still want that radiator setup for the V8. Hey Scott, lay off Jared. He is really in black ops.(IMG:style_emoticons/default/ar15.gif) that maintanence stuff is all cover. (IMG:style_emoticons/default/cool_shades.gif) I wouldn't piss him off if i were you. :finger2: |
skline |
Oct 17 2004, 10:26 PM
You a funny man, he is like a son to me, I am just worried he is going to rush it and not get it right. Quit Hijacking my thread. I need some answers.
JB 914 |
Oct 17 2004, 10:38 PM
Lighten up Francis I'm just trying to (IMG:style_emoticons/default/icon_bump.gif) you!
skline |
Oct 17 2004, 10:49 PM
Doesnt matter, I have a network partially down, I have to go to work now for awhile so I can find out whats going on. Hopefully someone will answer my questions before tomorrow.
OBTW, I know what movie that line is from, pretty scary. "Stripes" |
dan10101 |
Oct 17 2004, 11:05 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
I'm not sure what year motor you have or even if they are are different. On ours, there is a oil filter mount that contains the large threaded pipe that the oil filter screws into. That mount screws into the block with 2 3/8"(?) bolts. If it's loose, it could be causing a leak.
Ours was actually missing when we recieved it back from the machine shop. Here is a picture oil filter mount (IMG:http://racingarticles.com/images/29/photo2.jpg) |
sj914 |
Oct 17 2004, 11:17 PM
When you say that oil is coming from the oil filter, is it dripping from the top of it where the rubber gasket is?
One thing you could look at is the oil filter, is it the right one(ask me how I know). |
Elliot_Cannon |
Oct 17 2004, 11:28 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Hi Scott,
I meant to mention this when I was at your house. I'm sure you checked this and I don't mean to sound insulting but are you sure you have the correct filter for that engine? If the rubber gasket is matching up to the metal rim, I don't see how it is leaking. I've seen a filter that felt tight because the threads were tight but the seal didn't seat on the metal. Anyway my sbc knowledge is somewhat limited so maybe I sould shutup. I expect a ride in that monster by Christmas. LOL Cheers, Elliot |
rick 918-S |
Oct 17 2004, 11:36 PM
Hey nice rack! -Celette Group: Members Posts: 20,458 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
QUOTE(sj914 @ Oct 17 2004, 09:17 PM) When you say that oil is coming from the oil filter, is it dripping from the top of it where the rubber gasket is? One thing you could look at is the oil filter, is it the right one(ask me how I know). (IMG:style_emoticons/default/agree.gif) |
skline |
Oct 18 2004, 12:19 AM
Well, I had to go to work tonight so I am off tomorrow for awhile, I will get underneath there and take some pictures and look really close where it mates up. I put the first filter on after I painted the block and it had sealed itself on so tight I destroyed it getting it off. I know the gasket was seated against the metal as I had it upside down when I installed it and would have noticed it at that point. There has to be something else. I have that plate that Dan shows in the picture and it is installed otherwise the filter would have nothing to screw to. It has become a mission for me to figure out the oil leak first. So tomorrow morning, I am going under. I will post my results.
skline |
Oct 18 2004, 09:23 AM
Ok, Here are a few pictures of what the filter mounts to, it looks a little different from the picture that Dan posted but you can clearly see where the gasket seals to and I just cant see where it could leak. Any suggestions on what the problem is? Am I missing something?? Help guys, this thing pours out oil.
Attached thumbnail(s) |
skline |
Second picture
skline |
Oct 18 2004, 10:02 AM
Ok, Oil leak problem solved, I pulled the plate off where the oil filter sits and the bolts were not very tight, I put a little black RTV around the base of it and reinstalled it and the filter. Fired it up and no oil leak. Yahoo!! Now I will do the rest of it and get it test driven this week. I am still wondering about the cooling fans running after the car shuts off. So far it has not been a problem with running the battery down, but there are 2 batteries currently hooked up to it. I want to only run one when I put it on the road. Has anyone else run into issues running the fans after it shuts off?
Sammy |
Oct 18 2004, 10:04 AM
. Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
If the rubber gasket is the correct size and the filter doesn't bottom out on the threads it will seal. If the gasket is too small or too larger it will leak.
I don't know if running the fans after shutoff is a good idea or not. Most modern cars are designed that way but I'd be worried about running the battery down. Maybe a time delay relay to shut the fans down after as pre-determined time? |
Howard |
Oct 18 2004, 10:09 AM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Scott, I have a switch on mine, so option is there to have it continue running with the ignition off, but activated by thermo switch. Don't think it does much, as alum radiator cools down very quickly. Heat does build at engine, but cooling radiator won't help that with no pump running. Elec water pump with thermo switch??? How hot does it get? Mine can read 230 at engine and 140 at radiator after being shut down for 10 minutes or so.
skline |
Oct 18 2004, 10:13 AM
Mine goes up to about 210 after shut off and the fans turn off in about 5 minutes. Running an Optima battery I am not sure if I will have a problem or not. I am going to install a switch and light to tell me when the fans are running. The switch would be to turn them on when I want them to in case of thermostat failure at the radiator.
Lo-Fi Version | Time is now: 16th May 2024 - 09:47 AM |
