New wood door panels, Only the holes you need! |
Dr Evil |
Oct 18 2004, 11:15 PM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I figure that I would post this separately from my upholstery stuff as it is not a service as much as it is a good. I have these door panels that are laser cut from 1/4" high density fiber board. Very nice and only $40 a set!
Dr Evil |
Oct 18 2004, 11:16 PM
Pic
Attached image(s) |
i love porsche |
Oct 19 2004, 06:45 AM
Senior Member Group: Members Posts: 1,547 Joined: 6-May 04 From: Nutley, NJ Member No.: 2,030 Region Association: North East States |
whats the weight compared to a stock door panel?
Dr Evil |
Oct 19 2004, 11:25 AM
I don't know exactly as I do not have the weight of a stripped OE panel to compare it to. Mine weigh 1lb 11oz (.75 Kg) each.
Does that answer your question? |
Qarl |
Oct 21 2004, 06:33 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I would look into having these made out of a synthetic material, instead of fiber board.
The inside of the door panel is exposed to some moisture. That's why the factory had the plastic sheeting barrier there (to protect the door panel. There was a thread a while back on this... some suggestions were made...Sintra is one brand. It is a PVC based hi-density foam board. Often found at art stores. You could also coat the expo |
Dr Evil |
Oct 21 2004, 08:51 PM
Ya, I could, but these are $40 and what I have available. I am not making these, just selling. What would a comprable sheet of sintra cost? I am guessing more, but I honestly do not know. If it is easy to procure and cheap, and if I have enough interest in them I may go for it. The only thing is I am not doing R&D on things for a while as I have too many classes. I know that I could get these out of any color of acrylic if I wanted, but I have no idea of the cost. If moisture were a concern I would recommend either replacing the plastic shield, or spraying the pannels with some sealant. As they stand, the glue in them is a bit resistant and would deal with a usual amount of moisture for quite some time I imagine (so long as your seals are up to snuff).
rhodyguy |
Oct 22 2004, 07:43 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the doors should have a vapor barrier regardless. i think a water proofing product like thompsons, or something similar, would take care of the moisture break down issue.
kevin |
Dr Evil |
Oct 22 2004, 11:18 AM
I talked to the guy that makes these for me last night. He said that Acrylic would be too brittle, but he could make it out of poly carbonate and it would be bullet proof (litterally). Any PVC product is a no go due to the chloride gasses produced when cutting with a laser. As for the poly carbonate, the price would be as much as three times more. He recommended using Rhino lining on the door pannel back. It is tough as hell and water proof. Thats what he did and he likes it. He also put it on many other parts of his car for protection.
HTH |
MattR |
Oct 22 2004, 12:27 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
Sweet, I could use bullet proof doors living in LA (IMG:style_emoticons/default/biggrin.gif) .
djm914-6 |
Oct 22 2004, 01:59 PM
Happiness is: Getting on the road Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
Nah, Bulletproof would be too heavy. Make the entire door from Lexan. (IMG:style_emoticons/default/biggrin.gif)
MattR, does AirBoston ring a bell? |
jim_hoyland |
Oct 22 2004, 05:18 PM
Get that VIN ? Group: Members Posts: 9,272 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Just saturate the inside with resin. We do it all the time with stuff. You could also put wax paper down while it's still tacky and get an even better barrier !
MattR |
Oct 22 2004, 06:44 PM
Yep. Who is that? Do you two post on the same user name?
(sorry for the hijack mike) |
kid914 |
May 23 2020, 08:21 PM
ALWAYS lead...NEVER follow!!!! Group: Members Posts: 2,534 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
I know it s been a long time but wondering if these are still made. Thanks
Dr Evil |
Aug 8 2020, 09:19 AM
mepstein |
Aug 8 2020, 09:31 AM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I think 914rubber sells raw panels
@Mikey914 |
Mikey914 |
Aug 8 2020, 12:54 PM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We do complete door panels and are in production for an upcoming group buy.
We do sell panels and will open them back up in the next few days. So this is timely. We also have the vinyl and padding if you need it too. |
Hoppie944s2 |
Jan 4 2022, 01:20 PM
Porschenut Group: Members Posts: 64 Joined: 7-July 13 From: New Jersey Member No.: 16,098 Region Association: North East States |
Lo-Fi Version | Time is now: 4th May 2024 - 10:35 PM |
