Rebuilt fan components, so purty I thought I would share |
echocanyons |
Jun 23 2012, 05:18 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I recently had an engine built by McMark (IMG:style_emoticons/default/driving.gif) and I am now starting reassembly.
I figured that this was a good time to have some parts powder coated and hardware zinc plated. They turned out pretty good so I thought that i would share, here is the result of a couple of pieces. Attached thumbnail(s) |
echocanyons |
Jun 23 2012, 05:19 PM
shroud
JawjaPorsche |
Jun 23 2012, 05:36 PM
Wow! That is purdy! (IMG:style_emoticons/default/beerchug.gif)
Jun 23 2012, 05:44 PM
I would suggest you make sure the fan is balanced now that its all back together.
Rich |
Tom |
Jun 23 2012, 06:03 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Looking very nice! If it runs as nice as it looks, and it should having McMark rebuild it, you are going to be one happy TEENER! (IMG:style_emoticons/default/smile.gif)
Tom |
VaccaRabite |
Jun 23 2012, 06:04 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I would suggest you make sure the fan is balanced now that its all back together. Rich (IMG:style_emoticons/default/agree.gif) |
echocanyons |
Jun 23 2012, 07:09 PM
Thanks for the tip on the fan balance. How is a good way to test the balance of the fan?
rwilner |
Jun 24 2012, 06:14 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Is it a full rebuild? If so, you can get the whole rotating assembly balanced -- crank with gears, flywheel, pp, crank, fan. (I think that's everything.). Also a good idea to get your rods balanced end to end and matched to each other, as well as match the pistons. I think shooting for .5g between the heaviest and lightest is what you want.
Any competent machine shop can balance your stuff. I am new to engine building but that's what I am having done to my parts...others with experience may chime in. |
echocanyons |
Jun 24 2012, 08:27 PM
thermostat bellow rebuilt (as much as possible).
echocanyons |
Jun 24 2012, 08:29 PM
mounted
Bartlett 914 |
Jun 25 2012, 08:00 AM
76-914 |
Jun 25 2012, 10:00 PM
(IMG:style_emoticons/default/agree.gif) you shouldn't be able to slip much between those bellows when it is cold.
Elliot Cannon |
Jun 25 2012, 10:41 PM
Living in Clovis you ought to just get rid of it. Do you really need heat?
euro911 |
Jun 25 2012, 11:01 PM
I made the mistake of taking a fan apart to blast and paint without noting the original orientation. The machine shop had to drill a half-dozen extra holes in the back side of the fan to balance it (IMG:style_emoticons/default/dry.gif)
Lesson learned - I'll ALWAYS stamp some markings on the fan and pulley prior to dis-assembly to assure properly balanced reassembly (IMG:style_emoticons/default/idea.gif) |
echocanyons |
Jun 26 2012, 01:18 AM
Looks like the fan is heading to the local machine shop for a balance check.
Any Ideas where one can find a usable thermostat, they are pretty much NLA it seems. |
euro911 |
Jun 26 2012, 02:18 AM
If the shop says it's out and needs to be drilled, have them mark where the 'heavy' side is. Take it apart and reassemble with the small weight (on the inside of the front of the pulley lip) on the 'light' side and recheck the balance ... they may not have to drill it.
zonedoubt |
Jun 26 2012, 03:38 AM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
Any Ideas where one can find a usable thermostat, they are pretty much NLA it seems. There is a guy on the Samba selling new ones: http://www.thesamba.com/vw/classifieds/detail.php?id=1036746 |
reharvey |
Jun 26 2012, 05:08 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
Any Ideas where one can find a usable thermostat, they are pretty much NLA it seems. There is a guy on the Samba selling new ones: http://www.thesamba.com/vw/classifieds/detail.php?id=1036746 (IMG:style_emoticons/default/agree.gif) |
echocanyons |
Jun 26 2012, 09:04 PM
Great tips all (IMG:style_emoticons/default/smilie_pokal.gif)
echocanyons |
Jul 30 2012, 05:53 PM
How close is adequate when it comes to balancing the fan?
Lo-Fi Version | Time is now: 17th May 2024 - 04:49 PM |
