| Series9 |
Jun 26 2012, 08:27 AM
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,453 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
I'm sitting here with a factory manual in front of me and can't find /4 flywheel wear limits listed anywhere.
Help please. |
| r_towle |
Jun 26 2012, 08:30 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I would think its dependant upon the clutch...
You need that depression for the clutch...so you cant turn it too many times or the disk would rub all the time. rich |
| r_towle |
Jun 26 2012, 08:39 AM
plus you end up hitting the flywheel bolt heads also...forgot about that.
| JFJ914 |
Jun 26 2012, 08:58 AM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States
| SLITS |
Jun 26 2012, 09:12 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Siince the /6 and /4 are the same clutch, the following diagram should give you the limits even though it is a /6 - 901 Flywheel. Apparently, it has worked for others over the years.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1340723571.1.jpg) |
| JFJ914 |
Jun 26 2012, 10:23 AM
Deleted, worng information.
| JFJ914 |
Jun 26 2012, 10:59 AM
Siince the /6 and /4 are the same clutch, the following diagram should give you the limits even though it is a /6 - 901 Flywheel. Apparently, it has worked for others over the years. (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1340723571.1.jpg) The "C" dimension wear limit of 11mm does not work for a 4 cyl flywheel . I just measured my brand new (OE German) 4cyl flywheel and came up with a"C" dimension of 9mm uncut. This is 2mm shallower than a -6 flywheels' wear limit of 11mm. When you cut the 4 flywheel that 9mm dimension gets even shallower. I have been told that you can cut the wear surface even with the top of the 3 vent holes on the inside of the wear surface. Don't forget to maintain that "A"dimension differential of 22.5 mm. |
| rjames |
Jun 26 2012, 12:18 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,466 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
I tried long and hard to find this info but never did. But it is something less than 9mm as that's the measure when new. I ended up biting the bullet and buying a new flywheel to play it safe. Nice to know that the new one will most likely outlast the life of the car.
If you use yours, make sure that the top of the bolts don't sit above the surface. You don't want them making contact with the clutch disk. I think that's the main concern since you could adjust the clutch for a change of 1mm. |
| wingnut86 |
Jun 26 2012, 03:42 PM
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,054 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
That's the diagram I was provided and have used it twice. You "can" take it thinner, and if the bolts aren't flush you can grind them down or replace with suitable grade of allen head or similar.
Warning: if you shave the heads, be prepared to thin the sidewalls of a socket for the next removal or grind down an appropriate angled open end wrench. Keep in mind that torqeing going in is different and you need a helluva lot more PB Blaster coming back out. Oh, not recommended for the track or heavy hilly roads (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 12th July 2026 - 05:24 AM |
