14" 5 lug wheels |
14" 5 lug wheels |
microsa |
Oct 19 2004, 11:45 AM
Member Group: Members Posts: 94 Joined: 20-February 03 From: San Antonio, Tx Member No.: 329 |
Did any P-cars use a 14" 5 lug wheel?
boxstr |
Oct 19 2004, 11:53 AM
I just sold a set of 5, 14" five lug Fuchs from a 914-6.
CCLINNOFLUSHOT |
ArtechnikA |
yes. some 911E & T as the 'comfort option' and they showed up from time
to time on 914.6's. don't get your hopes up - 5,5" width only. good luck finding tires. Wheel Info Site |
cha914 |
Oct 19 2004, 12:38 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Tires shouldn't be that hard...lotsa bmw's still run around with 14's...I have a set of Azenis on mine right now...
Tony |
Gustl |
Oct 19 2004, 01:16 PM
914 enthusiast & historian Group: Members Posts: 11,503 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
QUOTE(microsa @ Oct 19 2004, 09:45 AM) Did any P-cars use a 14" 5 lug wheel? on early 912 standard: Fuchs 5 1/2 x 14 with 185/70 same dimension optional on 914-6 on some 924 (I think optional): 6 x 14 with 185/70 So long, Gustl |
microsa |
Oct 19 2004, 02:00 PM
What I am trying to get to is a 14" wheel that is wider than 6" that will bolt to the 5 lug in order to run as wide a sticky (Victoracer or 710) tire and get a little lower overall gearing for autocross.
ArtechnikA |
Oct 19 2004, 02:04 PM
custom time.
Mueller |
Oct 19 2004, 02:05 PM
Mike....read the rule books....PCA or SCCA or ???
in our region (PCA) we can run 14" rims, but only with 60 series tires....not too sure about SCCA, I've never run with them |
ArtechnikA |
Oct 19 2004, 03:57 PM
QUOTE(Mueller @ Oct 19 2004, 12:05 PM) ...not too sure about SCCA, I've never run with them in Prepared, you can run 14" slicks -- if you can find them... |
microsa |
Oct 21 2004, 09:48 AM
YellowDog runs C/SP, wheels/tires are pretty much open to what you can cram on there. I'm trying to get shorter tire/wheel combo.
ArtechnikA |
Oct 21 2004, 09:52 AM
QUOTE(microsa @ Oct 21 2004, 07:48 AM) YellowDog runs C/SP, wheels/tires are pretty much open to what you can cram on there. IIRC, no slicks in SP -- DOT tires are required... yes ? |
microsa |
Oct 21 2004, 09:59 AM
Kumho 710s. slicks w/two grooves in them, sort of like the F1 tire, sticky, but not THAT sticky! SCCA accepts them as DOT street legal tires. (Yeah, right!) But sadly not available in 14" Or Victoracers ECSTA V700 225/50/14
Lo-Fi Version | Time is now: 16th May 2024 - 12:28 PM |
