microsa
Oct 19 2004, 11:45 AM
Did any P-cars use a 14" 5 lug wheel?
boxstr
Oct 19 2004, 11:53 AM
I just sold a set of 5, 14" five lug Fuchs from a 914-6.
CCLINNOFLUSHOT
ArtechnikA
yes. some 911E & T as the 'comfort option' and they showed up from time
to time on 914.6's. don't get your hopes up - 5,5" width only.
good luck finding tires.
Wheel Info Site
cha914
Oct 19 2004, 12:38 PM
Tires shouldn't be that hard...lotsa bmw's still run around with 14's...I have a set of Azenis on mine right now...
Tony
Gustl
Oct 19 2004, 01:16 PM
QUOTE(microsa @ Oct 19 2004, 09:45 AM)
on early 912 standard: Fuchs 5 1/2 x 14 with 185/70
same dimension optional on 914-6
on some 924 (I think optional): 6 x 14 with 185/70
So long,
Gustl
microsa
Oct 19 2004, 02:00 PM
What I am trying to get to is a 14" wheel that is wider than 6" that will bolt to the 5 lug in order to run as wide a sticky (Victoracer or 710) tire and get a little lower overall gearing for autocross.
ArtechnikA
Oct 19 2004, 02:04 PM
custom time.
Mueller
Oct 19 2004, 02:05 PM
Mike....read the rule books....PCA or SCCA or ???
in our region (PCA) we can run 14" rims, but only with 60 series tires....not too sure about SCCA, I've never run with them
ArtechnikA
Oct 19 2004, 03:57 PM
QUOTE(Mueller @ Oct 19 2004, 12:05 PM)
in Prepared, you can run 14" slicks -- if you can find them...
microsa
Oct 21 2004, 09:48 AM
YellowDog runs C/SP, wheels/tires are pretty much open to what you can cram on there. I'm trying to get shorter tire/wheel combo.
ArtechnikA
Oct 21 2004, 09:52 AM
QUOTE(microsa @ Oct 21 2004, 07:48 AM)
IIRC, no slicks in SP -- DOT tires are required...
yes ?
microsa
Oct 21 2004, 09:59 AM
Kumho 710s. slicks w/two grooves in them, sort of like the F1 tire, sticky, but not THAT sticky! SCCA accepts them as DOT street legal tires. (Yeah, right!) But sadly not available in 14" Or Victoracers ECSTA V700 225/50/14
