Chris Foley's Tangerine Racing shift linkage kit |
Geezer914 |
Jun 28 2012, 08:46 AM
Geezer914 Group: Members Posts: 1,417 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I just finished installing Chris Foley's shift linkage kit. The car shifts smooth as silk like a normal car with a 5 speed. It's like night and day! There is no question what gear you are shifting into, the shifts are solid and tight. I first replaced all the bushings using the stock shifter. It was like "what gear am I going to find now?" It would grind going into 1st and my arm was hurting from pushing the shifter as hard as I could to the right to find 4th and 5th, and when shifting into 5th, finding 3rd instead! So I installed a Renn shifter, a little better, but not much. Was not happy. So I sprung for Chris's linkage kit and firewall bearing kit. The car is a pleasure to drive. Thanks Chris for a super engineering job and a high quality kit. If you are not happy with the way your car is shifting, I would highly recommend installing this kit. (IMG:style_emoticons/default/smilie_pokal.gif)
moggy |
Jun 28 2012, 12:23 PM
Member Group: Members Posts: 192 Joined: 15-December 04 From: Wales Member No.: 3,285 |
I see no advantage over the Rennshift kit with that. Good to have an alternative I agree. But if your Rennshift like for like kit wasn't working, which looks exactly the same, then I would be asking myself whether it was installed and setup correctly in the first place.
914340 |
Jun 28 2012, 12:54 PM
Newbie Group: Members Posts: 22 Joined: 15-August 10 From: Michigan Member No.: 12,057 Region Association: None |
I see no advantage over the Rennshift kit with that. Good to have an alternative I agree. But if your Rennshift like for like kit wasn't working, which looks exactly the same, then I would be asking myself whether it was installed and setup correctly in the first place. Good afternoon, to the best of my knowledge the Rennshift linkage kit is NO LONGER available. That being said, Mr Foleys linkage set-up is 'The Only Game In Town'. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:02 AM |
