Chris Foley's Tangerine Racing shift linkage kit |
Geezer914 |
Jun 28 2012, 08:46 AM
Geezer914 Group: Members Posts: 1,425 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I just finished installing Chris Foley's shift linkage kit. The car shifts smooth as silk like a normal car with a 5 speed. It's like night and day! There is no question what gear you are shifting into, the shifts are solid and tight. I first replaced all the bushings using the stock shifter. It was like "what gear am I going to find now?" It would grind going into 1st and my arm was hurting from pushing the shifter as hard as I could to the right to find 4th and 5th, and when shifting into 5th, finding 3rd instead! So I installed a Renn shifter, a little better, but not much. Was not happy. So I sprung for Chris's linkage kit and firewall bearing kit. The car is a pleasure to drive. Thanks Chris for a super engineering job and a high quality kit. If you are not happy with the way your car is shifting, I would highly recommend installing this kit. (IMG:style_emoticons/default/smilie_pokal.gif)
76-914 |
Jun 28 2012, 09:01 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
EdwardBlume |
Jun 28 2012, 06:41 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
(IMG:style_emoticons/default/agree.gif) but I'm pretty sure its mostly a long straight bar... FWIW my Rennshaft linkage popped off at the last autocross. Ended up back by the wheels. Maybe that's why its not made any more.... but the Rennshift a damn great shifter... |
ChrisFoley |
Jun 28 2012, 08:19 PM
I am Tangerine Racing Group: Members Posts: 7,929 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
... I'm pretty sure its mostly a long straight bar... In the case of a -4, the bar has 3 bends. (IMG:style_emoticons/default/biggrin.gif) My shift linkage kits are not a fabrication project as the JWest kits were. The kits are delivered ready to install, with a powdercoated shift rod that has permanently installed u-joint(s). However, installation does require modification of the sideshift console. |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:27 AM |
