Chris Foley's Tangerine Racing shift linkage kit |
Geezer914 |
Jun 28 2012, 08:46 AM
Geezer914 Group: Members Posts: 1,417 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I just finished installing Chris Foley's shift linkage kit. The car shifts smooth as silk like a normal car with a 5 speed. It's like night and day! There is no question what gear you are shifting into, the shifts are solid and tight. I first replaced all the bushings using the stock shifter. It was like "what gear am I going to find now?" It would grind going into 1st and my arm was hurting from pushing the shifter as hard as I could to the right to find 4th and 5th, and when shifting into 5th, finding 3rd instead! So I installed a Renn shifter, a little better, but not much. Was not happy. So I sprung for Chris's linkage kit and firewall bearing kit. The car is a pleasure to drive. Thanks Chris for a super engineering job and a high quality kit. If you are not happy with the way your car is shifting, I would highly recommend installing this kit. (IMG:style_emoticons/default/smilie_pokal.gif)
Eric_Shea |
Jul 16 2019, 02:50 PM
Jim, We put them on everything. The spherical firewall bushing is a must as well. That's a major slop area. A new factory firewall bushing is disgusting.
Everything should go as planned. This is one of the major improvement areas. With a short shift kit they're even more funnerer. Pull the trigger... (IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 03:41 AM |
