oil tem psender gaskets |
Jun 28 2012, 08:47 AM
does anyone have an exploded view picture of the oil temp sender gasket setup ...
I thought I put everything in, all new including the copper washers... Started dripping when I started the motor... Must have missed something... Pics would reallly help, I may have forgotten something. rich |
76-914 |
Jun 28 2012, 08:56 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Rich, I had a Hell of a time sealing my last one. Finally put some sealant around the small crush washers and the bolt threads. Some use studs in place of those bolts. (IMG:style_emoticons/default/beerchug.gif)
type47 |
Jun 28 2012, 02:03 PM
did you use the paper gasket between the base and the cover?
039.101.287 don't know if this would cause the leak, I would think the red o-ring or the crush washers would be more likely.... |
Black22 |
Jun 28 2012, 05:17 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
I just did this. I don't have a cover, taco plate only. I put some Loctite 565 on the O-ring, threads of the bolts and a small dab on the new crush washers as well. I did NOT want to do this again. Hasn't leaked in over a week and I've put another 60 miles on her.
The hard part is cleaning/ drying the sealing surface and installing the plate as more oil tries to drip from the engine. I drained all my oil, but there is always more looking to escape. |
Valy |
Jun 28 2012, 10:27 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
There is a big silicon o ring between case and sender holder. Then a paper gasket between the sender plate and cover. The holding bolts have copper washers. The sender also has a copper washer.
The copper washers are available in the HF copper washers set. The paper gasketsare in my rebuilding thread in my signature. |
Lo-Fi Version | Time is now: 14th May 2024 - 08:11 AM |
