WTB - brake hard lines, From rear firewall to rear caliper |
Jun 30 2012, 02:44 PM
914-6 GT in waiting Group: Members Posts: 19,262 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
WTB - Brake hard lines that run from pressure regulator on rear firewall to the rubber soft lines at the caliper. Must fit a '71. I might have parts to trade depending on what you need. thanks, Mark
jimkelly |
Jun 30 2012, 02:55 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
A&PGirl |
Jun 30 2012, 02:58 PM
Senior Member Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None |
Mark,
I think Eric Shea has what you're looking for. $38.00 + shipping according to his website. Rear Caliper Hard Lines Ack! Got beat. |
Black22 |
Jun 30 2012, 03:12 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
PMB's brake lines are the hard lines from the juction around the pivot point of the trailing arm (under the engine shelf) to the soft lines at the caliper.
IIRC there are two hard lines per side that get you from the regulator to the soft lines. I made my own with lengths from the FLAPS, a tubing cutter and borrowed their double flaring tool. Costs about $7.00 per side for rears. |
Jun 30 2012, 03:48 PM
PMB's brake lines are the hard lines from the juction around the pivot point of the trailing arm (under the engine shelf) to the soft lines at the caliper. IIRC there are two hard lines per side that get you from the regulator to the soft lines. I made my own with lengths from the FLAPS, a tubing cutter and borrowed their double flaring tool. Costs about $7.00 per side for rears. Black22 is correct. I have a set from Eric (rubber line to caliper). I'm looking for the long lines from the firewall to the rubber line. thanks, mark |
TheCabinetmaker |
Jun 30 2012, 03:58 PM
I have them.
Lo-Fi Version | Time is now: 13th May 2024 - 06:03 AM |
