QUOTE(Black22 @ Jun 30 2012, 05:12 PM)
PMB's brake lines are the hard lines from the juction around the pivot point of the trailing arm (under the engine shelf) to the soft lines at the caliper.
IIRC there are two hard lines per side that get you from the regulator to the soft lines.
I made my own with lengths from the FLAPS, a tubing cutter and borrowed their double flaring tool. Costs about $7.00 per side for rears.
Black22 is correct. I have a set from Eric (rubber line to caliper). I'm looking for the long lines from the firewall to the rubber line. thanks, mark
