air tube?, in door jamb |
type11969 |
Oct 20 2004, 02:24 PM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
I've seen reference to the "air tube" in other posts, it runs from the door jamb to I'm not sure where. So first question is, what is its purpose, and what are its connections? What years had these air tubes?
The reason for my confusion is that on my 71, there are these "air tubes" that start in the door jamb, but then just end shortly after that where they butt up to the inner fender wall. Both fenders on each side have been replaced (poorly), and I think that these air tubes might have come along with them possibly from a later model. It seems as though the air tube should have a matching hole in the door, but maybe I don't understand its purpose. Can someone please clarify them for me? Thanks, Chris |
bondo |
Oct 20 2004, 02:32 PM
They vent the cabin through a hole just behind the door, under the rear window, directly under the upper seat belt mount on the targa bar. It's at about armpit level when sitting in the car. That whole area is a rust nightmare, and it's hard to repair because of a brazed joint. I had thought all years had them, but I could be wrong. You may need to remove the side rollbar trim to see the hole. I'd think that blocking off the holes would be ok, considering these cars don't seal that well anyways.. You might find slightly less defroster performance, or less heat flow if there's no exit for the cabin air.
Oct 20 2004, 03:38 PM
yes, all cars had them. it's a vent. if you pump air into your car (heater, fresh air) the "old" air has to go somewhere. the vents ensure the air will circulate. they should have a small round black plastic cover with a filter in the door-jamb outlet.
the green arrow shows the outlet in the door jamb, there's a similar hole (but oval) on the inside of the car ... (IMG:style_emoticons/default/cool.gif) Andy Attached image(s) |
tbil |
Oct 20 2004, 04:03 PM
Newbie Group: Members Posts: 37 Joined: 16-December 03 Member No.: 1,439 |
Note that the felt plug that attaches to the black plastic cover holds water. Each time you wash or drive in the rain, it holds water against the body, at least on my car. Rust! I pull these and let them air dry, today in So. Cal. as it's dumping on my poor little daily driver.
bondo |
Oct 20 2004, 04:30 PM
If I remember right the early cars don't have the plastic grille and felt. Not much harm in leaving it out, just looks and maybe wind noise.
hargray2 |
Oct 20 2004, 06:09 PM
fuh-q Group: Members Posts: 302 Joined: 12-December 03 From: hardeeville,sc Member No.: 1,432 |
my '71 and '72 both have the black plastic covers. I do agree that this place loves to rust.
type11969 |
Oct 21 2004, 06:26 AM
Last night I found the other end of the air tube in the cabin, PO sealed it up with sheet metal and a bunch of screws . . . Along with the crap repairs on the fenders, should be real interesting to see what all he did when I pull the current fenders to replace them.
Pics will follow. |
Lo-Fi Version | Time is now: 21st May 2024 - 01:34 AM |
