A Long Winters Nap, Parked for about 6 months |
tracks914 |
Oct 20 2004, 07:13 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I just parked my car for the winter. (IMG:style_emoticons/default/sad.gif)
I found a good garage along with a friend of mine. Just 2 cars in it, a Mint '80 Z28 and my teener. For $100 apiece and the garage is closed up and left snowed in for the winter. I think I got a pretty good deal. I just have to go back tomorrow and take out the battery in the daylight. I was going to sprinkle baking soda all around the battery tray area to absorb any possible acid leak (next year I get an optima) and I put some wooden blocking under the car (just enough to unweight the suspension under the jack points but the tires still touch the ground). I put fuel stabilizer in the gas tank, drained my washer fluid tank and put a little extra air in the tires for they will bleed down when the temp hits -45*C this winter. Anything else that I may have for got? Tx |
Brad Roberts |
Oct 20 2004, 08:43 PM
WHOA. That is crazy. I couldnt imagine being without for that long.
B |
markb |
Oct 20 2004, 08:51 PM
QUOTE(Brad Roberts @ Oct 20 2004, 07:43 PM) WHOA. That is crazy. I couldnt imagine being without for that long. B (IMG:style_emoticons/default/agree.gif) |
ejm |
Oct 20 2004, 09:00 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
QUOTE Anything else that I may have for got? Poison bait to kill mice...they're prolly building a nest right now (IMG:style_emoticons/default/sad.gif) |
GWN7 |
Oct 20 2004, 10:12 PM
Moth balls to keep the critters out...
QUOTE WHOA. That is crazy. I couldnt imagine being without for that long That's why the make snowmobiles that go 150 mph (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/biggrin.gif) |
Carl |
Oct 20 2004, 10:55 PM
Ummm ... what? Group: Members Posts: 781 Joined: 17-January 03 From: San Jose, CA Member No.: 163 Region Association: Northern California |
QUOTE when the temp hits -45*C Whew! |
Mark Henry |
Oct 21 2004, 06:58 AM
Yep, getting near that time. I drive, on nice days, right up till the first salt hits the road. Then my baby goes away for a nap and repairs/mods get done in time for the spring. Temps don’t go down here as bad as Timmins, the coldest I’ve seen it is –30c. Most of the winter it hangs just below the freezing mark here.
I spray engine storage oil down the TB as well. |
Rusty |
Oct 21 2004, 07:34 AM
Yep. Don't store a dirty car!! Clean the car well, including the wheel wells, trunks and behind the rocker panels (where dirt accumulates, stores water and rusts).
Pull the battery out entirely. It'll only take 5 minutes, and then you won't wonder. Still do your baking soda routine. Clean the interior, focusing on any crumbs or spilled drinks (think - cold and hungry rodent smells something good and comes to chew up your interior.) (IMG:style_emoticons/default/wolfgang.gif) Mothball the hell out of the inside and the engine compartment. Some window screen material over the air intake and the exhaust. Wire it down with twist-ties, and you can see if any little critters have chewed their way in. Put down plastic sheeting under the car, to prevent moisture from going UP into your car. Yes, especially if it's a concrete slab. Lubricate all your seals (door, window, targa, etc) with some glycerine. You can put the car on jackstands, and pull the tires. That should help them from becoming flat-spotted. that's all I can think of right now. Hope this helps! -Rusty (IMG:style_emoticons/default/smoke.gif) |
tracks914 |
Oct 21 2004, 04:14 PM
Done Pull the battery out entirely. It'll only take 5 minutes, and then you won't wonder. Still do your baking soda routine. Done Clean the interior, focusing on any crumbs or spilled drinks (think - cold and hungry rodent smells something good and comes to chew up your interior.) (IMG:style_emoticons/default/wolfgang.gif) What.... crumbs in my car?...I don't think so, I don't let the kids eat in it. (IMG:style_emoticons/default/laugh.gif) Mothball the hell out of the inside and the engine compartment. Does this keep the rust moths from the hell hole? (IMG:style_emoticons/default/laugh.gif) Some window screen material over the air intake and the exhaust. Wire it down with twist-ties, and you can see if any little critters have chewed their way in. Good idea, never have needed that up here as we don't really have many rodents. (I don't think they will make it past the oil bath anyway (IMG:style_emoticons/default/wacko.gif) ) Put down plastic sheeting under the car, to prevent moisture from going UP into your car. Yes, especially if it's a concrete slab. Never heard of that one before either. With the winters running mostly about 10-30% humidity the air is pretty dry. Lubricate all your seals (door, window, targa, etc) with some glycerine. Done You can put the car on jackstands, and pull the tires. That should help them from becoming flat-spotted. Done that's all I can think of right now. Hope this helps! It did, if nothing else it gave me peace of mind to know I did as much as I could for this year. BTW - for the 14th year in a row, the guy with the Z28 next to my car, ran it though the local car wash, backed it in the garage, took out the key and walked away. His car is still in mint condition. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 02:06 AM |
