Well that's it...., Parked for another year.. |
crash914 |
Oct 21 2004, 05:12 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Woke up this morning....( a song there somewhere)..
looked at the temperature outside....31 deg F. and change...below freezing....This about kills my motivation to finish the car and drive it around the block until spring... Winter project will be 1. get the motor running 2. body and fender pounding 3. prep for paint. 4. Rust repair... What are your winter projects?? later, herb |
Jeroen |
Oct 21 2004, 05:27 AM
Same as the past 4 winters... Get the darn thing to look like a car again (IMG:style_emoticons/default/biggrin.gif)
ArtechnikA |
Oct 21 2004, 06:37 AM
QUOTE(crash914 @ Oct 21 2004, 03:12 AM) Woke up this morning....( a song there somewhere).. 1. get the motor running What are your winter projects?? get the motor running head out on the highway go look for adventure in whatever comes my way ... remove, rebuild, and replace the 911's engine remove, rebuild, and replace the transmission remove, rebuild and replace the 911's brakes and suspension remainder of track prep -- roll bar, belt mounts, etc... your basic 'strip out all the running gear, rebuild it, replace it' winter refit. each of those tasks blossoms into a thousand subtasks, of course ... Parade is the end of June -- love to have it done earlier - but that is the goal ... |
i love porsche |
Oct 21 2004, 06:43 AM
Senior Member Group: Members Posts: 1,547 Joined: 6-May 04 From: Nutley, NJ Member No.: 2,030 Region Association: North East States |
finish the chassis before winter (hopefully by next week to send it to the body shop to have it stripped and painted on the underside and engine bay) and install the wiring harness!
mikerose |
Oct 21 2004, 08:20 AM
Happy to be back Group: Members Posts: 657 Joined: 31-December 02 From: Pittsburg,ca Member No.: 60 Region Association: None |
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif)
Drive Drive Drive (IMG:style_emoticons/default/biggrin.gif) |
Rhodes71/914 |
Oct 21 2004, 11:55 AM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Has been below freezing nights here for a while but I am still going to get my car running this fall. But my winter projects are:
Finsish tearing down 2.0 motor Build up 2.0 motor - TBD how it gets built, new pistons, Cylinders? Heads reworked? Pull 1.7 out of car, clearn engine bay. Bunch of electrical stuff New targa seals And probably a whollotta stuff I don't even know about yet. |
sanman |
Oct 21 2004, 12:01 PM
Leaving California Group: Members Posts: 341 Joined: 17-June 04 From: Houston, TX Member No.: 2,219 Region Association: None |
Winter project? Winter starts in January in TEXAS (IMG:style_emoticons/default/biggrin.gif)
Bigbohr |
Oct 21 2004, 12:06 PM
Superlurker Group: Members Posts: 224 Joined: 19-September 03 From: Houston, TX Member No.: 1,176 |
QUOTE(sanman @ Oct 21 2004, 10:01 AM) Winter project? Winter starts in January in TEXAS (IMG:style_emoticons/default/biggrin.gif) Yeah, what winter? Heat index was over 100 yesterday. About time that AC stops churning and my electricity bill goes down so I can buy some parts. |
watsonrx13 |
Oct 21 2004, 02:09 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Winter, oh, you mean when the temp drops below 50F?
Our 'winters' are the summer months where the heat index is above 100 and afternoon showers. Not that a little heat and some rain would stop me from working on the car, especially since it's on jack stands. BTW, what is snow and why do you need to heat your garage/shop? Winter project: 1. Get rebuild motor from Joe (you DA MAN). 2. Remove the sound deadening in the passenger compartment. 3. Rebuild pedal cluster. 4. Repair rust in rear trunk. 5. Repaint engine compartment, passenger compartment, rear trunk. 6. Reinstall interior, including new carpet and seats. 7. Install engine/trans, adjust gas and clutch cables. Adjust trans linkage. 8. Install new brake pads and MC, then adjust brakes. 9. Install PORed gas tank and new fuel lines. 10. DRIVE THE CAR for the first time in 2 years. |
dakotaewing |
Oct 21 2004, 08:14 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
QUOTE(Bigbohr @ Oct 21 2004, 01:06 PM) QUOTE(sanman @ Oct 21 2004, 10:01 AM) Winter project? Winter starts in January in TEXAS (IMG:style_emoticons/default/biggrin.gif) Yeah, what winter? Heat index was over 100 yesterday. About time that AC stops churning and my electricity bill goes down so I can buy some parts. Huuuummmm.... Guys - If either one of you would have came to the MUSR, you would have actually experienced some pleasant, fall weather..... 50F in the evenings... 65F tops during the day............... Sorry we missed you! LOL -Thom |
Rouser |
Oct 22 2004, 03:59 PM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
QUOTE What are your winter projects??
crash914 |
Oct 22 2004, 04:31 PM
For all you guys and gals in warm sunny climate...bite me!! (IMG:style_emoticons/default/blink.gif)
UPDATE I used my truck, jumped from the truck to the starter and transmission, poured gas down the throttle bodies.....turned the key and lit the floor on fire.... IT LIVES!!!! Now to put in a new starter, battery, larger battery cables and repair my MS relay plate......I should be able to do this this weekend...... no snow yet....I might get the car around the block before the snow flies....... |
crash914 |
Oct 23 2004, 05:51 PM
I just repaired my relay plate, soldered a couple of wires to replace the burnt traces...works!!!
Now waiting on a new starter...... (IMG:style_emoticons/default/mad.gif) Will this never end?? |
Lo-Fi Version | Time is now: 17th May 2024 - 08:09 PM |
